3-22
23-26
Thanks Marco,
The alpha script is barely a beginning :-)
You're welcome!
...in truth is very "barely" :)
You also reminds me a custom command for filter curve based on length, that I started to code many month ago and I have never finished.
Later I will post here.
Maybe it can be useful also for you.
If you want you can use it :)
Stay tuned :)
Hi Brian.
This is the custom command that I was coding months ago and that I told you in my previous messages.
It's an alpha version of a "FilterCurvesByLength" command that I was coding and I never finished.
For the moment I have published only a brief demo video.
As soon as I have cleaned up the code I will publish also the command.
Take a look at :
http://moi3d.com/forum/index.php?webtag=MOI&msg=8608.19
Ciao!
Hi Marco,
I am interested in how you did the htm display in the sidepane.
Regarding script interface for Curve and CurveSegment objects:
To clarify my understanding of the crv.evaluateTangent, and crv.evaluateDerivatives:
'FromLeft = true,' calculates tangents or derivatives, at points associated with NURBS parameter "t," with a "direction along the curve," starting from the domainMin towards the domainMax.
domainMin is associated with the start point of the curve.
domainMax is associated with the end point of the curve.
The values of the tangent or derivative is given as (x,y,z), a vector.
Sometimes the tangent vector values appear different from the 1st derivative values, but I think that the two vectors are parallel?
FromLeft = false, reverses the "direction" of calculation of tangent or derivatives. (INCOMPLETE STATEMENT, Only at discontinuity, see Michaels response.)
(Flipping the curve would result in reversing of FromLeft true vs false vector results. (except maybe at a corner point?))
For a straight line, all of the 'FromLeft = true tangents' for all of the points on the line, will be the same, as will all of the 1st derivatives.
In order to make a "Clothoid Blend" from a start point of a curve, the tangent at the startpoint will (MAYBE) have to be the "FromLeft = false" version. (FALSE)
A curve with a "corner point" in it, with non-tangent curve segments joined at the corner point, would have a discontinuity at the corner point. (This is like saying if it is not straight, it is crooked, a tautology :-)
The parametric "direction" across the join at the corner point is one way.
I think that the Blend command would benefit from incorporating "crv.isClickSelectedNearEnd" ?
For non-corner point tangents of a curve, the 'FromLeft = true' tangent is 180 degrees from the 'FromLeft = false' tangent. (FALSE)
At a corner point with the discontinuity, the 'FromLeft = true' tangent will not be 180 degrees from the 'FromLeft = false' tangent. (Otherwise the corner point is not at a discontinuity?)
A CurveSegment is part of a curve consisting of joined segments.
Selecting a curve selects all of its segments.
Is there a corner point between all joined curve segments?
To tell if a curve has curve segments, Separate the curve. Is there another way?
The tangent has the same direction as the derivative but the tangent is normalized so it is a unit length vector.
Not quite - the FromLeft parameter only has an impact at a discontinuity. At a discontinuity there can be 2 different tangents at one single parameter value and "FromLeft" chooses whether it returns the tangent of the segment to the left or the segment to the right.
Say for example there is a curve like this:
If you evaluate the tangent right at that t = 6.3 location there is a discontinuity there and there are 2 possible tangent values, one from this segment (let's call this the "left segment":
And then there is a different tangent direction using the right segment:
The FromLeft parameter determines which of these 2 will be returned, if FromLeft = true (the default if you don't specify it) the one from the left segment will be returned, FromLeft = false means the one from the right segment will be returned.
The tangent is still in the overall direction from the start to end of the entire curve, so setting FromLeft = false does not reverse the direction of the tangent, it just picks which of the 2 will be returned.
Flipping the curve would result in both a flipping of all tangent directions and also which segment's tangent would be returned by FromLeft true vs false, since now the other one is lower in segment order.
This is true if it is a simple 2 point line. If it's a curve made up of many control points which all happen to be arranged in a line then the tangents will be the same but the 1st derivatives will change depending on the control point spacing.
Nope - if you want to have a direction pointing opposite from the start tangent of a curve you would evaluate the tangent of the curve with "FromLeft" not having any impact whether true or false, and then you would modify the tangent by multiplying it by -1.0 to flip it.
Yes, a tangent discontinuity.
The Blend command already uses it internally in the blend factory.
Nope - at non-corner points there is only one curve tangent and either FromLeft = true or FromLeft = false will return the same value there since the tangent as seen approaching the point from lower in parameter space (FromLeft = true) is the same a the one seen by approaching the point from higher in parameter space (FromLeft = false).
The evaluated tangent is always in the direction of start to end of the curve no matter what value you specify for FromLeft.
Yup. In MoI each segment is restricted to be tangent/G1 continuous. If there's a break in tangent continuity the segments will be divided there.
Pretty much, but it's implicit, it's only the parent curve that will have obj.selected == true.
Yes, although it is possible for a corner point to still be tangent continuous if the segments happen to be formed that way (which is not unusual, for example a curve that is filleted will be like this). You'd only see a sharp corner in a case like that if you dragged the corner point somewhere.
The segments of a curve are returned by the getSubObjects() method which is available on every object type in MoI. A curve always has at least one segment. To see if it's made up of multiple segments you could do crv.getSubObjects().length > 1.
Hope this helps!
Hello Brian!
@You : "...I am interested in how you did the htm display in the sidepane..."
Oh...nothing special, believe me :)
I try to post the code within a couple of hours.
Stay tuned.
Thank you Michael,
I'm laughing at all the mistakes I made, and trying to remember calculus :-)
Thank you Marco
No problem Brian - it can take some time to become familiar with the naming conventions and things like that with all of this detailed low level stuff!
Ciao Brian.
Ok...here I am.
This is the zip file of my "FilterCurvesByLength" custom command, alpha version v. 0.5, Oct 07 2017.
http://take.ms/rwm9Q
It works on both V3 and V4.
For V3 and V4 you can unzip the archive and copy the two files into the standard "commands" folder of Moi
For V4 you can decide to copy the two files into the new C:\Users\<user>\AppData\Roaming\Moi\commands
To use this custom command you have to select at least 1 edge or curve.
It works on both kind of entities.
Keep in mind one thing before playing with this command.
As you can see, its UI needs a minimum amount of room to be shown properly, on my default Windows 10 config with default fonts, this room is "21em".
This size is related to the width of the "flex_vbox" into the file "C:\Program Files\MoI 4.0 beta Feb-9-2018\ui\SidePane.htm"
This custom command has almost nothing special as I said, and its Javascript code has no fancy in it.
It's already pretty fast but it could be optimized much more.
Anyway, besides its usefulness (I've written this plugin with 2D workflows in mind) it has at least one special feature :)
If you will test it you will see.
As you can see its UI has two main sliders, "Min" an "Max", referring to the length that we want to use as main "filter"
Well, the tricky thing is that the lower and upper limit of both sliders are automatically calculated when the command starts, based on the selected entities.
That's all.
Keep in mind that I never finished the coding of this plugin and it has for sure some hidden bug.
But for what I've tested so far it worked very well.
Enjoy!
Thank you Marco.
You're welcome!
Alert box with 6 curve values at each curve end.
It would be nice to have a persistent floating box?
I'll have to try for Normal and BiNormal, and torsion...
For a circular arc, 1/radius = "K" curvature. The curvature is the length of the displayed "position vector," = sqrt( x*x, y*y, z*z ).
4.9999999... ~= 5 :-)
Paul's online notes is helpful with reviewing the mathematics, and has pdf downloads.
Chrome web browser displays his site better than Internet Explorer does.
http://tutorial.math.lamar.edu/
_CurveExplorerVersion002.zip
Thank you so much for this tool, I am now downloading the MoI4 beta to use it.
I am an architect and have found it hard to find good curve tools on any program. I have used your Ionic Volute tool and that has hugely helped me.
I am copying the Parthenon and other Athenian buildings into MoI with dimensions from Stuart and Revett's 'Antiquities of Athens'. I believe this will help me with particularly hard curves, which I have drawn with theControl Point curve.
May I ask, are there any other scripts/tools for MoI, you know of, that may help me as an architect? I hope it is okay to ask, and I will keep searching the forums!
Many thanks for your help!
Charles
< <other scripts/tools for MoI, you know of, that may help me as an architect?
This ? (Here in French but of course is existing in English! :) (Press Original)
http://moiscript.weebly.com/cotations.html
Yes! Thank you very much Pilou.
Here are some examples of curves from mouldings of the Parthenon that I have had trouble replicating (in particular the S Curve in the lower circle):
- Again many thanks for your help, as being able to draw these curves will help me immeasurably! -
P.S. I haven't been able to open Curve Explorer, could it have been because there is no .htm file in the recent ZIP?
Put the file result of unzip inside the commands folder of Moi
then call it by Press TAB and write _CurveExplorerVersion002 (capitals or not anywhere but without any space)
or make a shortcut with the same word in the second column ;)
Else for the Drawing
Disable Snap Grid, Snap Direct
Press CTRL when you want "Sharp" angle
Put 3 or 4 Controls Point on the same part of curve with same curvature and of course a point at the inflexion! ( direction change)
Make zoom when it's hard to draw a point
Try to have same space between points if possible
At the end you can move the points as you want, add or kill someones...
Speedy test...as you see some points must bee moved at the end! :)
After some little moves seems perfect! :)
some similitude to this! :)
Thank you Pilou!
The curve explorer works, I thought it was a tool to draw curves and have now realised it is a tool to discover mathematical details of a curve. I am so sorry for any inconvenience.
Merci beaucoup, Through Points is a much better way to draw these curves than Control Points! I think I need to figure out how to upload a higher resolution image, as mine come out quite fuzzy.
I love Tintin! What a fabulous comic.
<< Through Points is a much better way to draw these curves than Control Points!
It's always "Control Points" ! ;)
If you want "Control Points" on the curve itself Press Tab and write "Rebuild" and input number Points you want!
(depending of the nature of your curve)
If now you take a "Point" of this new "rebuild curve" and move it you see that is always a "Contol Point"! ;)
3-22
23-26
