18-26
Yes! Thank you very much Pilou.
Here are some examples of curves from mouldings of the Parthenon that I have had trouble replicating (in particular the S Curve in the lower circle):
- Again many thanks for your help, as being able to draw these curves will help me immeasurably! -
P.S. I haven't been able to open Curve Explorer, could it have been because there is no .htm file in the recent ZIP?
Put the file result of unzip inside the commands folder of Moi
then call it by Press TAB and write _CurveExplorerVersion002 (capitals or not anywhere but without any space)
or make a shortcut with the same word in the second column ;)
Else for the Drawing
Disable Snap Grid, Snap Direct
Press CTRL when you want "Sharp" angle
Put 3 or 4 Controls Point on the same part of curve with same curvature and of course a point at the inflexion! ( direction change)
Make zoom when it's hard to draw a point
Try to have same space between points if possible
At the end you can move the points as you want, add or kill someones...
Speedy test...as you see some points must bee moved at the end! :)
After some little moves seems perfect! :)
some similitude to this! :)
Thank you Pilou!
The curve explorer works, I thought it was a tool to draw curves and have now realised it is a tool to discover mathematical details of a curve. I am so sorry for any inconvenience.
Merci beaucoup, Through Points is a much better way to draw these curves than Control Points! I think I need to figure out how to upload a higher resolution image, as mine come out quite fuzzy.
I love Tintin! What a fabulous comic.
<< Through Points is a much better way to draw these curves than Control Points!
It's always "Control Points" ! ;)
If you want "Control Points" on the curve itself Press Tab and write "Rebuild" and input number Points you want!
(depending of the nature of your curve)
If now you take a "Point" of this new "rebuild curve" and move it you see that is always a "Contol Point"! ;)
Hi Charles,
Burr's script list is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7841.6
Thank you for your continued help Pilou, I am just figuring this program out! It is an incredible program.
Charles
Brian,
Thank you for the link to command files, I wholeheartedly appreciate it.
Charles
Just a quick minimal test:
By minor modification to Michael's orderCurves script, adding a section for crv.evaluateCurvature, and crv.evaluateDerivatives,
arrows were created for the Curvature Vector, and the second derivative vector at segment points.
The curvature vector is orthogonal to the tangent vector. (?)
The Curvature Vector "k" points towards the center of (invisible) osculating circle, from the parameter point "t". (The magnitude is probably "K". (?))
(As a mathematics side note, Note that (capital K) curvature "K" is a scalar. I've been reading up on vector functions. )
For the test clothoid, the k curvature vectors pointed in the same direction as the second derivative.
For test circle, test open circle-oid, and test ellipse, the k curvature vectors were directed several degrees differently than the second derivative arrows.
The second derivative arrows were much longer than the curvature vectors.
I'd like to do an update to curveExplorer with these vectors, with different colored arrows, but have no time now.
The user could select desired points. Several styles would be available. There would be a persist option checkbox...
There could be checkbox options for the desired vectors.
In the test script, the curvature and 2nd derivative arrow style color will be the same, and the same style as your current style selection.
Tangents are lime green.
The attached file is a bare bones modification, alpha test version.
OrderCurves3TEST.zip
18-26
