Show messages: All
1-2
3-5
<< For the target point, drag out a construction line between the other 2 points and then snap the target point on that line
<< then snap the target point on that line
What is the best target ?
Middle Help Line, Perpendicular Help line, or any on Help Line ?
Because there are several "Snaped cross" who are "created" on the Help Line!
Whatever you decide makes the shape how you want it. There isn't any automatic "best" way to position control points, it's up to your own judgement.
Thanks Michael, a useful tip. I hadn't thought of using the Move command for this.
"At some point I'd like to see if I can get the Transform > Align command to also work with a custom direction instead of only horizontal/vertical."
That would be very welcome, thanks in advance.
Regards,
Metin
visualization • illustration • animation • 3D (print) design —
https://metinseven.com
Show messages: All
1-2
3-5
