Show messages: All
1
2-5
Hi Metin, you can use the Transform > Move command to do that.
Select the point you want to line up between the others.
Run Transform > Move.
For the base point snap on the point that you want to move.
For the target point, drag out a construction line between the other 2 points and then snap the target point on that line.
The dragging type move won't work for this both because it's awkward to create a construction line in it and also when dragging it won't snap onto other control points because that tends to make it easy to get points stacked up right on top of each other which degrades the quality of the curve.
At some point I'd like to see if I can get the Transform > Align command to also work with a custom direction instead of only horizontal/vertical.
<< For the target point, drag out a construction line between the other 2 points and then snap the target point on that line
<< then snap the target point on that line
What is the best target ?
Middle Help Line, Perpendicular Help line, or any on Help Line ?
Because there are several "Snaped cross" who are "created" on the Help Line!
Whatever you decide makes the shape how you want it. There isn't any automatic "best" way to position control points, it's up to your own judgement.
Thanks Michael, a useful tip. I hadn't thought of using the Move command for this.
"At some point I'd like to see if I can get the Transform > Align command to also work with a custom direction instead of only horizontal/vertical."
That would be very welcome, thanks in advance.
Regards,
Metin
visualization • illustration • animation • 3D (print) design —
https://metinseven.com
Show messages: All
1
2-5
