Show messages: All
1
2-4
Select Object(s). Open Library Menu. CLick on name Library ( symbol "+" appears)
Enter the object name. All selected objects will be added as a single library object.
If no object is selected, all objects will be stored in the library as a single object.
To import an object: Open Library, left-click - import object (object import command).
Right-click - Quick import (import command).
Use the central mouse button to rename the object.
Leave the name field blank and press OK to delete the object.
Hi mat10x,
I did it wrong, manually, before reading the original post by Max very carefully :-)
The correct, automatic way:
Click the Obj Library icon.
On the popup window, hover the mouse over the Object Library heading.
A "+" icon appears to the left of the Object Library heading.
Click on the "+."
This automatically creates a nice size/proportion png image.
Hi Pilou and Brian,
Ahhh...hidden little "+" symbol!
Works great now! Thanks so much guys!
M
Show messages: All
1
2-4
