8-27
28-32
Thank you Michael!
so easy to read with comments :)
I was searching for a way to add a shortcut for just "add trim point" and this result came back, but when I click on it it takes me to another post:
MoI discussion forum > Add Trim Point | Hotkey
Hello everyone. Hope all is well and that your CAD journey is rewarding. Anyone knows how one could make a hotkey for the Trim -> Add Trim Point command? Bests, -J. EDITED: 18 Oct 14:41 by BERUBE. Image Attachments: Size: 475.4 KB, Downloaded: 14 times, Dimensions: 1427x748px ...
moi3d.com/forum/messages.php?webtag=MOI
Anyway, I can't find the above post so is it possible to have a hotkey just jump right into adding trim points on a selected curve?
Hi yakas,
It's possible in the v4 beta - there's a new mechanism in v4 for automatically activating UI controls within a command. For "Add trim points" put this on a shortcut key:
Trim addtrimpoints
That will automatically push the "Add trim points" button when it shows up.
Some other ways to control the Trim command are:
Trim addtrimpoints removekeepmode=keep
Trim addtrimpoints removekeepmode=remove
Trim isocurve isodir=u
Trim isocurve isodir=v
A bit of "polishing" of the TrimCurve script is working out, removing segment names upon Done button pushed, (code from BlendCap), but work is not done yet.
Have not yet been able to remove names when delete button is pressed.
For some unknown reason, Naming is working better now.
It is nice to Comment out the Alert window in the code.
When using the script, it is helpful to (click) activate the Objects Tab in MoI. Then the segments can be selected, while still in the script...
Version 07, polished up quite a bit.
Handling of Standalone Curves is sometimes different that for Edges.
Object Names seem to be a bit persistent. They come back with Undo History.
Edit 1/18/2018
Here is the re-posted script.
I deleted a few comments. The script is nearly the same as version07.
_TrimCurve.zip
Something peculiar is going on when copying different versions of a script to the MoI command directory, and using customUI.
A functional script named _TrimCurve07.js, and .htm is in MoI's command directory.
A copy of the script named "_TrimCurve07 - Copy" is modified a little bit, with a missing "curve" variable, and copied to the MoI command directory.
The - Copy (seems) to run in MoI
If the defective "_TrimCurve07 - Copy" is renamed to "_TrimCurve08" it does not work.
So the lesson is do not use " - Copy" versions when testing.
This happened a couple of months ago... when this "crazy" behavior was first encountered.
This example is on a different computer...
(See next post.)
Okay, here is a very simple example of a version of the problem with Somescript - Copy.js, which is created in Windows7, 3rd option when copy pasting a script into MoI's command folder, using the _Angle.js script.
Copy _Angle.js from the command folder, to the command folder, using Windows7 3rd paste option, which yields _Angle - Copy.js.
Do not copy _Angle.htm.
Copy _Angle.js again, and rename copy to _AngleSecondCopy.js,
and do not copy _Angle.htm to _AngleSecondCopy.htm.
_Angle - Copy (seems) to run fine.
_AngleSecondCopy will not run correctly.
Using TAB and MoI's command entry window line, has the same behavior.
(Revised) conclusion, MoI does not recognize _Angle - Copy.js. Instead MoI just runs _Angle.js. (???)
(A reminder to myself, not to jump to conclusions, there could be another explanation:-)
Hi Brian - you can't have spaces in command names. That's because of being able to have command line parameters sent as well, which are separated by a space from the command name.
So for example if you set up a shortcut key with: SaveAs c:\temp\test.obj , it won't try to run a command script of "SaveAs c:\temp\test.obj.js" , it runs SaveAs.js and the c:\temp\test.obj after it is a command line parameter to the SaveAs command.
Similarly if you try to run "Somescript - Copy" it's going to look for Somescript.js and the "- Copy" will be a command line parameter, not part of the command name.
Michael, thank you very much for the explanation.
When testing scripts, so as not to overwrite a version, I sometimes used the 3rd option on the copy/paste, which has the not-allowed spaces.
I'll stop doing that :-)
I wonder if there is some version control software that uses notepad++?
Google of "version control with notepad++ is getting some hits. I'll do some more reading...
I somehow managed to create an open curve which has strange behavior.
Running _TrimCurve on it with a setting of 8 segments, results in 7 segments.
One of the 7 segments is of double length. It failed to divide.
Multiples of 8, such as 16, 24, and 32 also fail to divide all of the segments. Approximately 1 or 3 segments are lacking.
This strange curve, as an open cone, came up while testing _ObliqueConeUnwrap script, which works for a right circular cone, but not for
an oblique cone, (yet). :-) The shape of the Net is not quite right...
StrangeOpenCircle.zip
Looks like this is a tolerance related bug in the Trim command, on this particular curve it's ending up using too tight of a tolerance which makes it think that point was not on the curve.
I've got it tuned up for the next v4 beta so it should work ok then. Thanks for posting the file!
Thank you.
Is it possible to fix in MoI3?
Or is the "tolerance bug" in the C++ Trim factory?
MoI4beta seems to be working very well overall, so one of these days I'll move over to version 4!
With _TrimCurve test script, on higher powers of 2, or 8, such as 512, 1024, and even 512+1024, the segment count is 3 short.
In either MoI3 or MoI4Dec2017beta. At these "high" point counts, MoI3 has a several second lag in Done completion,
MoI4Beta is very fast.
Testing with stock Trim command in MoI3 or MoI4DecBeta, show the "bug," for this particular curve. Other open curves work just fine.
Scaling the curve, 2X, also shows the "bug," But a new arc "on top of it," does not show the bug.
Two last tests:
Using 64 points, _TrimCurve yields 61 segments. (3 are of double length, unsplit)
For standalone open curve, if the 61 segments are then Joined, and the _TrimCurve repeated, 64 segments result, the correct number.
(For an open edge, using Merge on the 61 segments, and repeating _TrimCurve with 64, results in 64 segments.)
Second tests, with stock Trim command, with start point added, yielded 1023 points versus 1024, one less than correct number of segments.
I'll try adding start point to _TrimCurve test script...
For standalone curves, I'm going to put a scripted "Join" and re-Trim in the _TrimCurve test script, as a "workaround" for MoI3.
Likewise for script in progress _ObliqueConeUnwrap.
For edge curves, I'm going to attempt to put in a scripted "Merge".
Adding startpoint to the already arrayed points seems to do no harm, in case of open standalone curves or open edge curves,
and so will be added for consistency with closed curves.
Yes it's in the Trim factory. Right now it doesn't seem likely to get fixed in v3, all my effort is going into v4.
cool :-)
Great, thank you.
Thank you Michael.
I see, by adding an alert to the BlendCap script, which starts with a Closed edge, that the number of edges is stated as 3.
Since TRIM resulted in two "half" edges, is this an overstatement by 1, or is there a 3rd edge? (Or something else?)
(The index count in the BlendCap for loop would seem to be 0, 1, and 2... ?)
var brep_edges = trim_res.getEdges();
//// Test Code added by Brian:
moi.ui.alert ( 'number of edges = ' + brep_edges.length )
(Result is 3)
(When Trim is applied to an open edge my tests in _TrimCurve12, (work in progress), show an "overstatement" of the number of edges as 2. ???)
(I'm planning on deducting this 1 or 2 count, for doing number of segments comparison...)
Hi Brian, well probably there are 3 edges being generated somehow, although maybe it's something like an edge is being repeated in the list.
Can you please post your modified BlendCap script with anything that's required to duplicate your test so I can try it over here and see what's going on?
8-27
28-32
