Hi ..
Now and then I create a flat surface (or hope to) by offsetting lines (or copying) and then drawing lines between the ends and using 'join' to connect. Then I use the 'planar' command to create the surface ... but there are times when that does not happen. I can't see that the curves are not planar or properly joined.
When this happens I open the drawing in Rhino and use 'closecrv' command which reports that a segment has been added.
Then back to MoI and the planar command creates the surface.
Is there a way to do this without going to Rhino for the fix?
eric
Hi eric, there's a CloseCurve command for MoI here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2752.2 . That will make a line segment between the ends of an open curve like the Rhino CloseCrv command.
Hope that's what you were looking for!
Hi Michael ..
Thanks, yes that's perfect!
eric
