Full Version: Gaussian Mirror...
Show messages:  1-7  8-23
6 Jan 2018   [#8] In reply to [#7]
Well I am totally confused.
Can you post a link to the Thea author article?
Gassian mirrors are also called Variable Reflectivity Mirrors
The link here shows an equation and a "bellish" curve, for describing the reflectivity, which seems to be done by optical coatings, with minimal or zero
physical curvature of the mirror.
http://www.standaphotonics.com/variable-reflectivity-mirrors/
http://www.altechna.com/product_details.php?id=927
https://www.lasercomponents.com/us/product/gaussian-mirrors/
6 Jan 2018   [#9]
Well, i would like to post this tutorial, but i'm not sure if this
is allowed, because non-registered users can't see this tutorial
and then i have to contact the author for permission, i guess. :-(
But let's forget for a moment all this laser optics stuff, how do
i have to measure or construct properly "a flat fruit bowl surface" with
a curvature angle less than 10 degrees, let's say for example 9.5 :-)
If i can do this properly i "only" must play with the light settings,
i assume, in order to get the desired result.
6 Jan 2018   [#10]
O,k the shape should look something like this:
I used an arc with 9.5 as settings and then revolved it.
Is this now the right approach to get the curvature settings
lower than 10 degrees?
6 Jan 2018   [#11] In reply to [#10]
From the geometry of the spherical mirror, note that the focal length is half the radius of curvature:
The angle of curvature is show in the link, as ...???
http://hyperphysics.phy-astr.gsu.edu/hbase/geoopt/mireq.html
I'll have to study the math and drawing for a while... :-)
6 Jan 2018   [#12]
Thanks for looking into it, much appreciated! :-)
6 Jan 2018   [#13] In reply to [#12]
I have not been able to find the definition of the "curvature angle of the mirror"
Assuming the curvature angle = angle of incidence of the parallel ray, then the 9.5 degree arc of a circle,
resulting from the rotation of a radius curve by 9.5 degrees,
would be the curve to be revolved to form the mirror.
6 Jan 2018   [#14]
Thanks very much for your explanation.
I tried it now and i must fiddle a bit with the light settings distance etc..
Would had been cool if the tutorial had some some sample files to study...
6 Jan 2018   [#15]
after googling a bit i think i found an easier solution, instead of using a gaussian mirror.
I will check this out tomorrow and if all goes well, i post my findings.
Best regards
7 Jan 2018   [#16]
i went by this explanation, for a normal concave mirror, which is also easy to understand.
http://physics.tutorpace.com/mirror-formula-online-tutoring
Best regards
Bildschirmfoto 2018-01-07 um 19.24.29.png  Bildschirmfoto 2018-01-07 um 19.25.20.png
7 Jan 2018   [#17] In reply to [#16]
Thanks Stefan.
That is a good tutorial.
22 Jan 2018   [#18]
a little late...but this is the result:
Maybe i try as next Young's double slit experiment with Thea and MoI.
Best regards
22 Jan 2018   [#19] In reply to [#18]
Hi Stefan.
Impressive results.
Maybe you could elaborate what is going on?
Part of white light beam reflects, part refracts
Refracted light again reflects and refracts, to rainbow, etc.
How is the rainbow of colors achieved. Does the color spectrum reflect physics and reality? (Within the limits of rgb colors?)
Is the prism flat on all sides, or concave?
So MoI made the prism?
22 Jan 2018   [#20]
in order to see the light beam and the rainbow colors, volumetrics (for the scene)
and dispersion (for the prism) is enabled. Thea is one of the very few render engines
who can do this stuff and according to their slogan is physically accurate.
The prism (made in MoI) is flat on all sides and filleted at the edges. I used this form
of a prism to see how it compares to the Pink Floyd Album Cover The Dark Side of The
Moon. Maybe they used for their illustration a regular tetrahedron, rotated at a certain
angle, i don't know.
Best regards
22 Jan 2018   [#21]
P.S. i always wanted to try this Pink Floyd Cover*, but if you download a trial of Thea Render
and check their sample scenes to download (Laser Lab) or look at their fantastic gallery, you
will see of course much better sample images, regarding this.
*I tried this with the free Lux Render years ago and Blender, but could not get the light beam
parallel, due to the lack of knowledge at this time.
Best regards
22 Jan 2018   [#22] In reply to [#18]
Wanderful result Stefan!!
I haven't followed this whole thread (Gaussian Mirror) but I suppose that the rainbow effect and the refraction
are "simulated" and not physically rendered with the unbiased engine of Thea.
I say this because for what I've tested so far, doing a simple 4k render of a scene like this
took almost 8 hours on my i7-7700K and unfortunately the Unbiased engine of Thea is not GPU bound (like the superfast Presto engine on my 1080 Ti).
But if you have tons of cores then it should be possible to render a "physically" calculated refraction rainbow :)
Anyway...great result!!
Congratulation Stefan.
22 Jan 2018   [#23]
Remember this incredible free prog! ;)
Phun : now it's called Algodoo!
Try it : it's terrific! :)
http://www.algodoo.com
