Show messages: All
1-4
5-14
Any chance we'll see something like that Rhino edge function in MOI V4? Really nice to be able to move edges on the fly.
I also tried the "chamfer/single and 2 distances" in MOI...in an attempt to get the same affect.
Left example chamfered (not in 2 distances), but only when the inside side recesses where chamfered. Right example yellow edge won't chamfer or fillet at all.
Thx.
Mat
Hi mat,
It's probably not too likely - it's kind of a weird function that can make strange lumpy results in many cases.
It's more common for CAD programs to have a "Transform face" function rather than transforming edges. That will probably require a new geometry library to be implemented in MoI for that to happen either though, so I'm not sure when.
To get the same result in MoI, you could draw a triangle profile, extrude it, and then boolean it like this:
It's not exactly what shows my previous video ? ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=8767.4
Oops sorry Pilou, yes it's the same thing.
Absolutly no problem! :)
Thanks for the vid. Understood on how to make that example cutout with multiple steps. I was more interested in being able to quickly move that edge up or down from a quick one step iterative perspective. "Hmm, too high, too low, ahh just right"...click. Done. Quick work flow. It's a nice feature in Rhino and Fusion 360. I'd just prefer not to the to stop MOI, jump over to Rhino to slide one edge up/down, stop, then jump back over to MOI...if possible.
Understood that MOI is not set up like that. I can dream though! ;)
I was hoping Chamfer 2 Distances would work on that front edge to quickly play with a chamfer angle...but no go there either. It'll only do a 1mm fillet or chamfer...not sure why. Top edges of the rectangle allow for chamfer 2 distances. Is it that the shape has been trimmed already on that lower front edge?
Thx.
That's how I would have done that too. Was hoping for a quicker one-stop-shop method.
Thx for the vid.
Hi mat,
I think it's because this is a more complex area to handle, where the side wall surfaces need to be extended, rather than just having areas trimmed away:
I do hope to be able to improve that in the future but it's going to require a lot of work with integrating a different geometry kernel so I'm not sure when that will happen.
Show messages: All
1-4
5-14
