7-25
Wanderful!!!
Many thanks!!
Wow great work Marc, thanks for sharing your progress pictures!
Wow, impressive work, from start to end result! MoI rules!
How did the bass turn out? How do you like it?
Hi Neil,
It sounds great, a bit like a Musicman Stingray (minus 6 pounds!).
It plays every week with the band!
I still have some minor electronics problem with the ground, it produces a bit of noise.
I’m by no means a professional builder, just an enthusiast.
I did follow a course in instrument making when younger.
Marc
I make my own mogami's... could be there too...
Active electronics. I didnt see any of the foil in "the parts" picture.
HI Burr,
Do you play music?
I didn't know about mogamis, looks like interesting cables.
Yeah I did put in the copper foil, the problem must be somewhere else.
I'm not very good with electronics...
Marc
Hey Marc,
Yes. Rock.
Mogami W2524 is very good cable, sheilded well. Dispite what you may read, makes a huge difference. Expensive to buy, not bad if you make your own (i do)
Yes, it can take time to track down what can be in several areas.
Do you have a chain in the loop? Try bypass that.
Also, a ground loop in the ac could be the cause. If you dont have a device with a ground lift, you can try a different outlet, or better yet, a differet path to breaker being sure to unplug other components from the loop to check... good luck!
Awesome job - beautiful bass!
Hi Burr,
Yes sir, rock from the Islands!!
We play a mostly funk instrumental blend.
Thanks for the pointers, very generous of you.
I've tried on different amps/cables and get the same results
I will try and draw a schematic of how it is wired when I get some time, it will help me double check it.
The jungle of cables in the pit can be confusing.
Marc
"Funk instumental"
In the 70's i was huge on billy cobham, tony williams, return to forever stuff..... close! Has to be rock now. Cant remember more than 3 chords! :o
Drawing out the wire pile will help for sure. My brother recently replaced and rewired a michael kelly semi hollow and needed a second pair of eyes rewiring. Took us a good 2 hours to stare at it and follow!
Anyway, low B all the way brother!!!
I'm in the right place to make this question :)
In the early 80's i have bought a second hand Gibson Les Paul De luxe,then sold when stopped to play
It was a Gibson:very comfortable to play,low action and so on,but had a little different shape of the body
The "horn" was very rounded,not as the classic Les Paul shape.I highligth in the picture the part
It was a Gibson?They produced something like that in the past?
Now,at 56 years i restarted to learn guitar :)
M
Hi Burr,
""""billy cobham, tony williams, return to forever stuff"""
I listened to them a lot !
Jeff beck's "Wired" is in my favorites of those years.
I recently discovered "Man-Child" by Herbie Hancock, good!
Marc
Hi Mauro,
I don't know guitars that much.
Maybe Burr, Neil or someone else would know.
Marc
Start with serial numbers:
http://archive.gibson.com/en-us/Lifestyle/ProductSpotlight/GearAndInstruments/Gibson Serial Numbers/
Then move to the craftsmanship:
http://www.gibson.com/news-lifestyle/features/en-us/CounterfeitGibsons.aspx
You'll find even gibson can struggle with identity, but passing these first 2 tests is a big plus!
Michael walden on led boots was monster!!!!
Saw herbie in a crater festival here 40 years ago!
You and i are kindred!!!!
Indeed, quite the Hi-hat lesson there ! :)
Marc
Great project. Question: 1 pickup but 3 pots? Why?
Hi Sebastian,
It's 3 stacked pots for a filter type pre amp, a bit like Alembic or Wal basses.
There should be a 4th one for passive tone but I didn't install it.
1 : Volume / Blend (dont use blend since it's a single pickup)
2 : Low pass filter / Amount
3 : High pass filter / Amount
Marc
7-25
