Show messages: All
1-3
4-16
Hi Karsten!
Thanks very much for the hint!
Does there exist a node that turns an object into a point? I couldn't easily find one.
What I'm after is: instead of creating a point and manually entering the frame location (as you suggested, above), wouldn't it be nice if you instead could use i.e. the centre of another object as reference?
I tried this with the "ObjtoArray" node: it's possible to connect the "Array" output to the "Frame" input of the "Rotate" node, but then there is no output (count is zero). Please see attached "knee" example. For some reason, it is necessary to always re-assign/update the "knee" and the "bone" after loading.
Any feedback is highly appreciated
regards
Bernhard
P.S.: a constraint solver would certainly be nice, but I'd be happy if there's an easy (fully graphical) way to add rotation (and optionally translation) control.
knee.3dm
knee.nod
Hi bemfarmer,
Thanks for the feedback!
Is there a general advantage to use reverse motion over the mathematics node?
best regards
Bernhard
Hi Bernhard,
I just mentioned the tictac mode as a possibility.
- B
Hello Berhard,
please check this files. You have to use the nodeeditor extensions for that (
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.750). Copy the included files under nodes\extensions and restart MoI. I have used a line to evaluate the rotation points and named all parts, so you can use getByName.
Have a nice day
Karsten
p.s.: Don't forget the file in libs.
knee.3dm
knee.nod
Hello Bernhard
I used your file to show you a possible route to
determine your rotation Frames ..
furthermore, underneath I have automated the movement with
the Quartz node ,and using the new Switch node
to stop the movement at the beginning of the action ..
I hope you can help
Have a nice day
alberto
Ps- file at this link:http://www.mediafire.com/file/xlmauruxc2o4pd8/Ailerons.rar
Hi all!
Thanks very much for the feedback. I appreciate it!
So the trick is to define "hinges" and then get their frames with the BoundingBox node.
I have attached a very simple stick & rudder example for an aircraft control.
best regards
Bernhard
P.S.: I still have some questions on the other examples, but I'll send separate posts.
aircraftcontrol.3dm
aircraftcontrol.nod
Hello Bernhard,
you can also use the getCrvStartFrame node as a replacement for the getBoundingBox if you use lines as your rotation axis. The advantage would be that the z-axis of the frame is always aligned to the line direction. Only difference: You have to rotate around the z-Axis. Al shows that in his example. Al: Thanks for that.
A nice day to all
Karsten
p.s.: It looks like that we will have a MoI airplane to fly through our MoI worlds next time. If Ralf will bring a camera to the airplane ...
I think it must be a GIMBAL camera... ;-)
Hi Karsten,
getCrvStartFrame works for me as you described, thanks for the hint!
best regards
Bernhard
Hi!
Inspired by Karsten knee example, above, I created a simple robot arm with three joints and grouped the nodes in a way that makes the cascading better visible: the same block is used three times - I guess it would be possible to create a macro for that.
However, I'm still wondering if it's possible to do this cascaded rotation much simpler: at the moment, the whole thing is rotated, at first. Then everything is split in order to work on the next joint (and so on). I think it would be much simpler if only the first "bone" and "joint" are rotated and the rest orients itself accordingly. Maybe I need to use RotatePts, instead, building cascaded frames?
BTW.: I made a few observations:
1. "Concat" appears to be limited to six inputs (the "Inputs" field is greyed out in the right click pop-up menue after slot "f" has been created).
2. Of you need more than one clone, then you need to cascade Clone. Does it make sense to extend Clone for more than two outputs?
best regards
Bernhard
robotarm.3dm
robotarm.nod
Hi!
Here's a variant that doesn't need concatenation and splitting via idxSelect, but it doesn't look as clean.
However, there is one advantage: in the previous version, it was necessary to manually enter the indices, whereas this version can be done fully graphically.
BTW.: what's the difference between "RotatePts" and "RotatePts"? I tried both and in the robotarm2 example and they are doing the same thing.
best regards
Bernhard
robotarm2.nod
Hi!
Here's a mix of robotarm.nod and robotarm2.nod from the earlier postings. It's using only two objects for the concat and idxSelect stages, so there is no need to figure out the indices manually.
It looks cleaner, but I'm still not happy that the angles also need to be propagated through Math adders. That works ok for this example, rotating all objects around the same axis orientation, but if you need to rotate around several axis then it probably won't work as expected.
Mathematically, this is just a simple chain of vector calculations. It would be great if this could be mapped to nodes without tons of house-keeping around it. In this context, a experimented with the "vectors" in the extension, but couldn't yet archive the desired result.
BTW.: it appears that the "Rotate" node only makes use of the position of a supplied "Frame", but it doesn't use the orientation information. As far as I can tell, that would probably make it easier.
feedback is highly appreciated!
best regards
Bernhard
robotarm3.nod
The rotate axis command uses the right hand rule, per M.G.
- B
Show messages: All
1-3
4-16
