Show messages: All
1-2
3-6
Hello Michael.
@You : "...One thing to note is that the surfaces involved in the pocket are a lot more complex than they seem..."
Hmmm....very interesting...
@You : "...I'd probably recommend doing a boolean of a box to make this indentation instead of Inset..."
Many thanks for your help! :)
@You : "...Did you need any help to finish the model? It sounded like you were able to get a good result on it from Rhino..."
You already helped me with your reply.
Usually I much prefer to use Moi over Rhino :)
Thanks. I will let you know the results with the fillets after the boolean operation.
Perfect Michael!!!
Applying the fillet after the boolean, instead after the inset, works !!
Thanks a lot!
Strange thing anyway :)
Hi Marco, I'm glad that works!
So the reason why Inset uses offset surfaces for it's "side walls" is so that there can be a constant wall thickness for the general case, here's a bit of an exaggerated example:
The wall thickness goes like this:
Thanks a lot for such a detailed info.
Ciao!
Show messages: All
1-2
3-6
