8-27
28-47
48-67
68-87
168-176
Hi Michael
I've found a bug.
Step by step :
open MoI v4 beta Dec-11-2017
open Option panel
close it
> crash
I sent you the crash report
<<open MoI v4 beta Dec-11-2017
<<open Option panel
<<close it
<<> crash
Not for me :) Windows 10
Same here on Mac....
But also (sometimes) while changing ShortKeys..
Hey Michael, I am having some problems with shortcut keys on the Mac. Fist there are duplicate entries for things like undo (Cmd+Z on the Mac) it also has a Windows entry of Alt+Z. I can't seem to set any shortcuts using Cmd+. I sometimes get a crash when attempting to set shortcuts. Crash report attached.
MoI_2017-12-12-135428.crash
Hi Ralf,
> this is not working: Box3pts WidthHeight width=2 height=4
It looks like here you are trying to use the new variation of the box 3pt command that I posted yesterday?
The problem here is that the command name for that is Box3ptsWidthHeight, without any spaces in it, you've got a space in the middle of yours above.
> @Michael (just a little very cosmetic error from my part) (3 times in French "objects" must be "objets" tiny isn't it! : escaped till now! :)
Thanks, I've updated this for the next beta.
Hi Shane,
Yes, there's still a problem with Alt+ and Cmd+ getting confused with each other. I'll be looking at that for the next beta and I'll be checking out the crash today, thanks.
re: options dialog crashing on close on Mac, looks like one of the changes for fixing the "mouse moves get ignored in some conditions" are causing that. I'll roll out an updated version soon.
Seems a Mac a very sensible machine ? ;)
Hi Pilou, well this latest crash is from a mistake I made, it happens to be in an area of mouse event handling that is by its nature kind of sensitive.
There are some things that I have found frustrating with the Mac though, like the full screen mode and the "spaces" mechanism is very poorly documented and hard to control.
But I expect things to be reaching a good level of stability soon here.
Hi Finema & Ralf & shane - re crash on closing options dialog on Mac, I just updated this to a new Dec-12 version which should hopefully fix that, please let me know if you still see it.
Thanks, - Michael
Thanks for the update, it's OK now.
That's great Finema, thanks for testing it! There are still some things to fix but hopefully we should be at a pretty stable version now.
Does it necessary to reload the PC version ?
<<<<<The problem here is that the command name for that is Box3ptsWidthHeight, without any spaces in it, you've got a space in the middle of yours above
Yes but i tried different versions with or without space...
Looks like its not implemented right now..
Hello Michael,
for me on Win10, F10 Shortcut is not working, in previous beta this was OK.
- Scarab
No there's no changes for the Windows version.
Hi Ralf,
Did you install the plug-in into MoI's commands folder?
Hi scarab,
> Hello Michael,
It looks like you've got the FullScreen plug-in installed in the previous beta but not installed in the new one, you'll need to copy it over into the new beta's commands folder to make the new beta able to locate it.
Hello Michael.
@You "...There are still some things to fix but hopefully we should be at a pretty stable version now..."
Wow! That's great!
Does it mean that soon you will able to start coding new features for this V4 ?
Have a nice day.
8-27
28-47
48-67
68-87
168-176
