21-40
41-60
61-80
81-100
161-176
Does it necessary to reload the PC version ?
<<<<<The problem here is that the command name for that is Box3ptsWidthHeight, without any spaces in it, you've got a space in the middle of yours above
Yes but i tried different versions with or without space...
Looks like its not implemented right now..
Hello Michael,
for me on Win10, F10 Shortcut is not working, in previous beta this was OK.
- Scarab
No there's no changes for the Windows version.
Hi Ralf,
Did you install the plug-in into MoI's commands folder?
Hi scarab,
> Hello Michael,
It looks like you've got the FullScreen plug-in installed in the previous beta but not installed in the new one, you'll need to copy it over into the new beta's commands folder to make the new beta able to locate it.
Hello Michael.
@You "...There are still some things to fix but hopefully we should be at a pretty stable version now..."
Wow! That's great!
Does it mean that soon you will able to start coding new features for this V4 ?
Have a nice day.
Aaaaah now i understand....
I was thinking its some new implementation which accesses the old commands...
Hi Marco,
Not quite yet, but that's getting close! There is still some work left to fix some remaining bugs and still a couple of display features to implement to reach full parity with v3. But getting rid of the bugs that most interfered with normal operation is a pretty big milestone, it seems like that's where things are right now.
@You : "...is a pretty big milestone, it seems like that's where things are right now..."
Wanderful!!!!
Thanks a lot Michael.
P.s. please don't forget to resume the display of "snap" labels :)
Ciao!
Hi Ralf,
Well, there is indeed some new stuff that can be used with old commands for setting default values used by controls in the command, that's what those example shortcuts for Trim and Extrude are doing.
But that particular one you were trying was a customized command that altered the box3pts workflow a little bit for what Andreas was wanting to do. So for that to work at the moment you'd need to install the custom command.
It probably does make sense to incorporate an option for that behavior within the regular box commands too though, but that's not how the box commands are currently set up, because they don't currently try to look at any default values for width and height. They're expecting the width and height inputs to be changed just by moving the mouse around. They only grab width and height values from the controls if you type stuff directly in them.
Maybe I can tweak the new mechanism a little bit though - like if the control is marked as being non-persistent like the box width/height are, it should fire a UIEvent for that control (which will then trigger the script to get the values from them) rather than only setting the default. Maybe if I set that up then it would work with the regular existing box commands too.
Hi Marco,
Yes, that is one of the remaining display features that I was referring to.
Metin reporting for duty, Sir!
New MoI installed on MacOS High Sierra. First impressions are fine, no issues encountered yet. No crashes or freezes.
Hi Metin, thanks for testing it - sounds good so far!
The command "Print3D.js" is not included in the new beta(?)
Please consider adding "Nudge.js" to the "stock" commands(?)
General Windows 7 observation, nothing to do with MoIBeta: When windows explorer is "docked" to half screen view,
and when preview is active, trying to highlight, copy or paste should not be done in the preview area, IMHO.
Thanks Michael,
my mistake. You are right. Now F10 function is working for me.
Many thanks, by the way this is Super suport and very nice community.
- scarab
Yeah I removed it since it didn't do anything. At one point in the past it was going to be for integrating with a separate program called Print3D which does not exist anymore.
Adding Nudge to the commands that ship with MoI would be great indeed. I couldn't live without it.
Hi Metin.
What is "Nudge" ?
I admit my ignorance about that...
21-40
41-60
61-80
81-100
161-176
