Hi Sculpy, MoI itself is only focused on modeling and doesn't have any photo-realistic type rendering built into it. So you need to export your model to a rendering program to do that. There are various rendering programs available - Simlab Composer that Pilou mentioned above is a great one to check out.
To move your model over into Simlab Composer for rendering you can export from MoI to .obj format and set the option for "Output: Quads & Triangles" in the mesh options dialog, then open the .obj file in Simlab for rendering.
