Full Version: V4 beta Nov-13-2017 available now
Show messages:  1-12  13-32  33-52  53-72  73-92  93-112  113-132  133-152  …  213-231
14 Nov 2017   [#73]
Hi, some stranges behaviors: sometimes when selecting an object, nothing shows , no style name, no dimension. And the construction lines often cannot find a point or a line.
Moujjik
14 Nov 2017   [#74] In reply to [#73]
Hi Moujjik, thanks for reporting these bugs. Let me try and focus on the construction line one first - is it possible for you to make a simple example file where it happens reliably when creating a construction line between 2 specific points? That may help me to repeat it over here. Also do you see any different behavior if you set View > "Display hidden lines" ? - Michael
14 Nov 2017   [#75]
Is it my imagination, or has the font for MoI3 changed to the font for MoI4?
Especially for Ext.Scripts.
- B
14 Nov 2017   [#76] In reply to [#72]
Hi Finema,
> I've remove space after slash and font is ok now but Options and Help are still near Ext.scripts
Try switching the inserted script tag line in CommandBar.htm to have a closing </script> tag like this:
<script type="text/javascript" src="customui/CustomInit.js"></script>
It looks like the newer parser is more strict about not allowing self-closing script tags anymore.
14 Nov 2017   [#77] In reply to [#75]
Can you post a screenshot?
Hmmm, looking through it here I can see a bug that would cause that - looks like v4 reads the font name from moi.ini from a new UIFontNameV4 value to try and keep it separate from v3 but writes it back out as just plain UIFontName which is the same one used by V3. So if you happen to have Open Sans installed in your system font folder that would indeed show up in v3.
I'll fix it up so v4 will both read and write to UIFontNameV4 to keep it separate from V3.
14 Nov 2017   [#78] In reply to [#76]
Michael
i've delete function LlamaMode() code in commandBar and it's Ok now
see my screenshot and the commandbar file
thanks
14 Nov 2017   [#79] In reply to [#76]
Michaels mod to CommandBar.htm moved the Options and Help buttons back over to the right, where they belong.
(I did not remove Llama)
14 Nov 2017   [#80] In reply to [#68]
<< French accents
For me seems all is ok!
Problems arrive when Notepad++ save in bad format Ansi / UTF (I never remember what is the good one!
For the moment seems its's coo! :)
For the moment the unic mini problem is that the classic Windows NotetPad don't take in count the "Line(s) Break (s)" !
14 Nov 2017   [#81]
Windows 10
Helper lines are not dashed! Does it normal ?
14 Nov 2017   [#82] In reply to [#66]
Hello Michael.
Your're welcome!
@You : "...At this level what is the approximate 3D view performance in MoI v3? You can enable the time display in v3 by:
script: moi.ui.showViewportDisplayTime = true;..."
Perfect. I will make this test this evening or night and I will let you know the results.
Clearly I will make this test with the same machine (my desktop PC).
Could you please collect in one single new thread or a single downloadable pdf file, all the little changes that we have to make to
the V4 UI' files in order to make it works with custom UI or in order to update custom html/js plugins written fo V3 ?
A simple "to-do" list where you collect all the little html/js changes that we have to make.
So, in this way we are not forced to search through this thread ("V4 beta Nov-13-2017 available now") all the posts related to that argument.
Thanks a lot.
Have a nice day.
14 Nov 2017   [#83]
Windows 10 - 13 Nov 2017
Suddenly Freezing of some function(s) !
Does exist a trick for reccord artificially like a "rapport error" ?
Here I have just the file 3dm! (simple is not it ! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/freezing.3dm
14 Nov 2017   [#84] In reply to [#83]
Hi Pilou.
@You : "...Suddenly Freezing of some function(s) !..."
I have downloaded the file and have no issues.
Which "functions" are you referring to ?
Ciao.
14 Nov 2017   [#85]
PS Does it possible when you engage the Extrude function to keep the last option when you recall it by Right Click?
for example when you choose Set Dir, this one is not recalled and kept when you remake the Right Click for another Extrude!
In testing
Repeat the freezing!
I just draw a box Select an edge/ Extrude / Set Dir/ Extrude... Right Click Select an Edge / Set Dir/ Extrude etc...
Go to the forum in the same time (multi task)
Return to Moi ...freezing all functions!!! (I can save the file)
Seems the exit time of Moi makes the freeze functions of modeling!
My V3 works fine for the same thing! (Moi/ Forum/ Moi)
14 Nov 2017   [#86]
Hello Michael,
Congrats on the release.
I'm testing in Wine. I know it's not a priority and I'm not looking to get it fixed now, but I hope you will be able to help getting things going under Linux with Wine too later on.
My experience so far (I will test further as soon as I get the chance):
1.Installs fine, no problem.
2.Fonts look OK. No more changing registry keys to make them look good.
3.Snapping isn't working at all
4.Selection isn't working. I can't select curves and edges, and no matter where I click it can only select one solid (the first created) or, on second click, one of the faces (the bottom one)
5.Slight performance improvement in a bigger model
Toolbars:
1.Draw curve and draw solid all work as expected.
2.Edit/view/select: can't test curve editing (can't select curves), everything else seems to work fine
3.Construct: can't really test, Transform: seems to work fine
You mentioned a while ago that it can work with OpenGl or DirectX. Is there an OpenGl mode?
As far as I can tell it still uses DirectX.
14 Nov 2017   [#87] In reply to [#85]
@You : "...I just draw a box Select an edge/ Extrude / Set Dir/ Extrude... Right Click Select an Edge / Set Dir/ Extrude etc..."
Pilou, I don't get any issues but I didn't fully understand what you described.
Please make a video.
Ciao.
14 Nov 2017   [#88] In reply to [#81]
> Windows 10
Yup - from the first message of this thread:
"The only known areas still not quite working yet are snap text labels and dotted/dashed line styles in viewports and Mac trackpad gestures aren't fully functional yet."
But don't worry they will be coming back.
14 Nov 2017   [#89] In reply to [#87]
No need video : all functions are freezed : impossible to click on button Cancel etc...
So some ennoyous! :)
Ps And I can't Make video as I must exit of Moi for that! So that freeze it! :)
14 Nov 2017   [#90]
I've just installed MoI V4 beta Nov-13-2017 for Mac OS. It's great to have MoI in its native, non-WINE glory again. I've missed that feeling a little since moving from Windows to Mac OS.
My system specs:
• iMac (27-inch, Late 2013)
• Processor: 3.5 GHz Intel Core i7
• Memory: 16 GB 1600 MHz DDR3
• Graphics: NVIDIA GeForce GTX 780M 4 GB
Here are my first observations (my apologies if some of this has been reported before):
• I like the font and the clear look of some new icons, such as the History, Copy and Paste icons.
• I love the new keyboard shortcut input.
• Some keyboard shortcuts I had assigned to Command + key have been automatically changed to Alt + key, such as Alt + I for ImportObj in my case. But pressing Alt + I didn't work. Then I reassigned it to Command + I again, and the shortcut worked. Other Alt + key combinations such as Alt + O to open a file do work though.
• The viewport update feels a bit snappier than the WINE version. I'm very pleased with that, although I haven't tried a heavy scene yet.
• Pressing the Mac OS system shortcut to toggle full screen mode (Control + Command + F) doesn't work.
• The viewport labels (Front, Perspective, etc.) initially show as blocks:
… After I had created something I noticed that the labels appeared in the boxes, along with a number that varies when I hover over different viewport elements. I guess this is a debug thingy. :)
• Max's FatLines script returns an error.
• The Loft command update seems to operate differently than before, and gives a different result compared to recreating a Loft from the same curves...
— I created three copies of the same ellipse curve, and used points in the center of the outer ellipses to end the loft in a polar manner. I then used Loft with the Loose and Exact settings, and no capping. This was the expected result:
— When I change the position of some ellipse points, extra connecting lines appear, making the Loft object less smooth (to my experience this didn't happen in V3):
— Deleting the Loft object and re-running the Loft command on the points and ellipses results in a different, smoother object, although still with multiple connecting lines in stead of one:
— Rebuilding the Loft with the Auto option (in stead of Exact) does result in one connecting line:
Regards,
Metin
visualization • illustration • animation • 3D (print) design — https://metinseven.com
Screen Shot 2017-11-14 at 10.46.15.png  Screen Shot 2017-11-14 at 10.57.00.png  Screen Shot 2017-11-14 at 11.23.11.png  Screen Shot 2017-11-14 at 11.25.58.png  Screen Shot 2017-11-14 at 11.34.52.png  Screen Shot 2017-11-14 at 11.39.44.png
14 Nov 2017   [#91]
congratulations on the V4 beta release!
The UI looks a lot better on my non-retina MBP running High Sierra, especially the fonts and antialiasing.
Its really nice to have a native, 64bit macos version :-)
It did a quick test of the scripts that i wrote or help write (LightingOptions, CVolume & ScriptPallete) and they work fine.
The only thing that i noticed is that the scripts that use moi.ui.createDialog will not return focus to the main Moi window after i close the Dialog if Moi is running full screen.
Dinos
14 Nov 2017   [#92] In reply to [#82]
Hi Marco,
> the little changes that we have to make to the V4 UI' files in order to make it works with
Yes I can do that once I actually know what they are. But also I may be able to tune up some things so no action is needed, I just need to know what isn't working the same.
