Full Version: V4 beta Nov-13-2017 available now
Show messages:  1  2-21  22-41  42-61  62-81  …  222-231
13 Nov 2017   [#2]
Also if someone with a Retina screen Mac could please post screenshots of both V3 and V4 with some objects showing I'd appreciate it so I can see if that is working as expected or needs any tuneups. Hopefully v4 should look a whole lot better there now.
Thanks, - Michael
13 Nov 2017   [#3] In reply to [#2]
Here 2 screen shot of ma y Imac Retina 5K
my first try on In V4 beta :
- name of view panel is very little
- can't open several documents simultaneously
- fillet and chamfer don't run
- all tools don't run (revolve, extrude, loft) > calculating in loop
PS : if you need some others screenshots, don't hesitate to ask me.
JP
13 Nov 2017   [#4] In reply to [#1]
Hi Michael ..
Thanks ..
cheers,
eric
13 Nov 2017   [#5]
Thank you.
Rudl
13 Nov 2017   [#6] In reply to [#3]
Hi JP, thanks for the Retina screenshots. That's great, it's working properly on Retina now, UI text and icons look great now and the 3D viewport content shows full resolution. I know about the viewport names in the upper-left corners, text display inside of the viewports is still something I have left to work on. Please let me know if you see anything else at half size other than that.
What method are you using to try and open them, is it by double clicking on a file in Finder? What happens if you choose "New Window" from the menu bar at the top of the screen?
13 Nov 2017   [#7] In reply to [#3]
Hi JP,
Hmmm, yeah it seems that asynchronous factories got broken somehow recently on Mac, I'll look into that tomorrow.
13 Nov 2017   [#8] In reply to [#6]
If i double click on several files in Finder > that open me several MoI windows (ok)
New Window from the menu is ok
i've updaded my post because tools don't run
thanks
13 Nov 2017   [#9] In reply to [#8]
Hi JP, yeah I see that a bunch of commands aren't running on the Mac version, they are all the ones that do their work in a separate moi_commandprocessor process. It works ok when running under the debugger over here which is why I didn't happen to run into that. It's probably something like a path isn't set right, I should be able to fix it tomorrow.
13 Nov 2017   [#10] In reply to [#9]
ok
an other thing
Sometimes i can't draw any curves or solid on scene.
See my screenshot, the panel on the right stay empty and it's impossible to drax something
13 Nov 2017   [#11]
<< also linked to from the download page on the main web site.
Don't see any link of that! ;)
13 Nov 2017   [#12]
Hi Michael
Thanks a lot.
The UI working more or less properly on Retina.
Drawing seems to work well.
There is a problem with all operations (fillet, chamber, boolean, ofset etc.)
Cheers Stefan
13 Nov 2017   [#13]
Michael, congratulations on launch! Exciting stuff. A quick 10 minute pass (no custom ini, just playing) and it all looks GREAT! Looking forward to spending more time playing soon :-)
13 Nov 2017   [#14] In reply to [#11]
> << also linked to from the download page on the main web site.>
It seems to be there ok... Maybe hit reload on your web browser?
13 Nov 2017   [#15] In reply to [#14]
Yep : reload was the trick! Sorry for the disturb! :)
13 Nov 2017   [#16] In reply to [#1]
Hi Michael!
Thanks a lot for your efforts !!!
This is a brief report :
My laptop config is :
Windows 10 Pro 64 Bit English
i7-4790K 4.0 - 4.4 Ghz
32 Gb Ram 1600 DDR3
Nvidia Quadro K3100M 4Gb 768 Cuda Cores (Driver Version 385.69)
SSD Samsung 512 GB
1) Just downloaded and installed. No problem at all :)
2) All V3 shortcut keys works properly with the V4!! Thanks!
3) I spent few minutes playing with the new V4.
I downloaded some 3dm files.
4) Loading is OK
5) To stress CPU/GPU I'm using a 5 degrees mesh angle
6) I recorded this video to show you V4 running on my laptop.
I noticed these things :
A) It seems that there is no speed gain compared to V3, both in terms of loading and in terms of navigating the viewports (:
B) It seems that V4 has the same issue of displaying "fake edges" in some part of the models
C) As you can see in my video, the antialiasing of edges and above all of surfaces's boundaries is unsatisfactory.
I didn't touch anything in my Nvidia Control Panel.
I'm using V4 as is.
This is the video : http://take.ms/ywed7
7) I have also copied all my custom commands/scripts to the new V4.
In next days I will let you know what works and not works correctly.
Thanks a lot again.
I stay tuned.
Ciao.
13 Nov 2017   [#17] In reply to [#1]
p.s.
My laptop has a simple Full HD (1920x1080) panel.
Just some example screenshots :
Ciao!
13 Nov 2017   [#18] In reply to [#16]
Hi Marco, thanks for testing it!
That's expected right now and it's good in fact that there isn't any regression. I haven't had a chance yet to finish the work on speed improvements by making use of lots of available VRAM, there is some of the infrastructure in place for it but that's something that I will be working on more once things stabilize. Please remember this is only the first beta and does not contain everything that I want to have in the final v4 release in it as of yet.
That's expected, it should behave exactly the same as V3 right now.
Same thing here, it's expected to behave the same as MoI v3 at this moment. But it will not be difficult for me to add in an option to enable MSAA once the initial stabilization is done.
Thanks, - Michael
13 Nov 2017   [#19] In reply to [#18]
Ok Michael!
@You : "...Please remember this is only the first beta and does not contain everything that I want to have in the final v4 release in it as of yet..."
Got it! :)
I stay tuned.
I will let you know my next test results ASAP (I think only late at night...)
Ciao!
13 Nov 2017   [#20]
Here the FrenchStrings.txt updated! ;)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/frenchstrings.txt
just a little thing : seems there is no more "line break" when edit with the normal Windows NotPad !
works fine with NodePad ++
13 Nov 2017   [#21] In reply to [#1]
Firstly, thanks for the V4beta! I look forward to big things
with my favourite app.
As already established, most tools don't work on a mac,
but I wanted to test custom UI and node editor.
As you can see both run with the beta, but this error
occurs when pinching on trackpad in NE.
Also some navbar buttons have disappeared.
Hope this helps
