Show messages: All
1-9
10
> The boxy mode is now some avoid by some tricky plugins! ;)
> So now SketchUp is also becoming a sort of Subdivision prog! (not so
> poweful than a real one but as it's so easy...;)
One of the things that makes SketchUp easy to use is that the main program UI has stayed focused on drawing lines on faces and using push / pull. That is cool that there's a plug-in that does sub-d smoothing but that type of modeling is very different from boxy line drawing push/pull modeling and so trying to use it for that is going to lose a lot of the easy to learn quality.
If you want to do sub-d modeling there are other programs out there that are focused just on that and have their entire UI tuned for doing that.
Show messages: All
1-9
10
