Show messages: All
1-4
5-11
do you think I can expect this level of precision and detail using MoI?:
https://tinyurl.com/yd7lq4jd
I missed in your previous post you were asking about text as well. Yes, an outline or text (vectors) could be extruded. If you want to conform to a curved surface, Flow could be used or trimming/boolean depending on how you want to generate the edge of the extrusion.
"Will MoI make these rings with precision"
Yes! But, you will be modeling all that stuff, and placing it on the ring. But that in and if itself is "precision"....
You mentioned and have probably seen "embossing images" for more complex shapes and designs... this is less precise, but can get extraordinary detail and organics. MoI does NOT do this....
Your best "embossing" stuff will come in CAM programs.
If you are "manufacturing" your items, actually modeling things is a good way to go.
Thanks for taking the time to answer my question Chris. Do you know if pave stone setting possible in Moi?
Thanks Burrman. MoI is so far sounding like it will fit my needs.
Great Utube tutorial.
Hello,
You can easily model items in MoI with features too small to be practically cast. I don't follow your question about precision, what pieces are you referencing against?
Show messages: All
1-4
5-11
