311-330
331-350
351-370
371-372
either in fillet tab (extra option for non-coplanar) or in blend tab with a corner selected (will act like fillet - thats why i'm more towards option in fillet tab) , both doing same thing, cut a distance and make blend together
the way i'm imagining cutting is a sphere growing radius from corner introduced by user, where sphere intersects with lines - make a cut & blend after, if growing sphere(radius) meets 3'd intersection point, algorithm fails
ofc if wont be fillet radius, but calculated radius (technically not part of fillet)
Hi Tudor, yes the problem is that if you cut something by intersection with a sphere then if you try to put in a circular arc segment between the cut pieces the arc will not be tangent to both cut ends.
311-330
331-350
351-370
371-372
