Full Version: Trimming question
 3 Nov 2017
To: ALL
So you'd only want to draw in lines for these spots here, the other 2 spots are slightly curved and you want to use the existing edges there rather than putting in a straight line:
Reply
 3 Nov 2017
To: ALL
Hi Involute, so in the attached file I ended up using Edit > Trim to cut pieces away and then used Construct > Network to build a filling surface and joined it in.
Also instead of just drawing in a line for the top of that red zone above I put in a control point curve that's slightly curved so it's smooth with the lower piece.
ConnectorTube2.3dm
Reply
Show messages: All  1-2  3-4
Reply to All
Back to thread list | Login
© 2018 Project Beehive Forum
