11-21
Hello Franz and everyone!
Here's and updated version of my "SelectCurvesByContainer" familiy scripts.
It is updated to "Nov 02 2017" and it's the most recent version that I wrote before abandoning the project for lack of free time :)
Please, follow these instructions :
If you have previous version of these scripts this shouldn't be a problem because these files have same names, so they will be overwritten,
but if you want to be sure to clean up everything, first delete every files inside the "scripts" folder whose name starts with "SelectCurvesByContainer",
and then delete the "repository2dworkflow" folder.
Then, follow these steps :
1) Download this zip files :
http://take.ms/IIZyA
2) Unzip and you will get these four files :
SelectCurvesByContainer_ALL.js
SelectCurvesByContainer_ClosedCurvesPartiallyProjected.js
SelectCurvesByContainer_Holes.js
SelectCurvesByContainer_OpenCurves.js
Copy them inside the Moi's "scripts" folder
3) Download this zip files :
http://take.ms/hYGfL
4) Unzip and you will get this folder : "repository2dworkflow"
Copy it inside the Moi's root folder, at same level of folders "commands", "scripts", "ui" as shown by this image :
That's all folks! :)
Let me know if you have still problem.
Ciao!
<< that are better than a simple image.
Sure for the use but not for the subject!:
Advantage of an image :
I a glanze you can see if you are interested against read a text or launch a video! ;)
When you make thousend things in the same time, any times winned is free times for make other things!
Ok, Pilou.
Next time I will post also some images.
Ciao!
Here's also and updated version of my
"LassoSelectCurves" family scripts.
but if you want to be sure to clean up everything, first delete every files inside the "scripts" folder whose name starts with "LassoSelectCurves",
1) Download this zip file :
http://take.ms/x4PyQ
LassoSelectCurves_ALL.js
LassoSelectCurves_ClosedCurvesPartiallyProjected.js
LassoSelectCurves_Holes.js
LassoSelectCurves_OpenCurves.js
Ciao!
<< Next time I will post also some images.
Cool! A Gif animated is also an "image"!
Nothing to load for the user!
Maximum efficacity!
Holy Wonderful!
Marco, Thank you SO VERY MUCH!
Thanks Marco, everything's working now!
Perfect!!
If you want to write everything related to "Lasso Select and SelectCurveByContainer", please use the new thread I created yesterday, instead writing to the old thread "Scripts for 2D Workflows" that I won't follow anymore.
The new thread is at :
http://moi3d.com/forum/index.php?webtag=MOI&msg=8830.1
Thanks and have a nice day :)
Marco (mkdm)
...little mistake in my previous post....
not "If you want to write anything..." but "If you want to write everything..."
Hallo Marco!
Thanks for your advice. I especially like the utility-list and command+script-history you use. Can you give me a tip where I could get this?
Thank you in advance.
Franz
Hello Franz.
I'm sorry if I repeat here my previous message...
"If you want to write everything related to "Lasso Select and SelectCurveByContainer", please use the new thread I created yesterday, instead writing to the old thread "Scripts for 2D Workflows" that I won't follow anymore.
http://moi3d.com/forum/index.php?webtag=MOI&msg=8830.1"
So in a few minutes, you can find my reply at the new thread :)
See you there, ciao!
11-21
