Show messages: All
1
2-13
Hi Chucky - I'm not really sure of Vitaly's specific workflow but typically it's fastest to work with solids and do booleans.
You might want to check out Chipp Walters' tutorial here on that general style:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7592.1
Vitaly is fantastic modeller...i would say close to 'that is it'.
As far as his methodology is concerned he uses possibly heaps of Moi but I think he has some
elements scripted in grasshopper with custom modules and things like Catmull Clark.
That is by the way my dream of the future. Simplicity of Moi with coding when needed.
To ad few more words....my personal flow in MOi is mainly based, similar to what Michael mentioned in his post, on use of Boolean/Merge tool.
To my knowledge, Bulgarov uses no grasshopper or Rhino. He likes ZBrush, and still uses the deprecated XSI.
Just like many of us here, he believes in the right tools for the job, which includes poly/SubD modelers, topology modelers and NURBS-- which of course is MoI. I actually started using MoI because of him. I'm sure there are many others.
He likes to "kitbssh" which you can do in MoI quite effectively. You may want to see my tutorial on it.
For the longest time he rendered in KeyShot, but had recently started rendering more and more using Octane.
Screenshot-2017-10-27 Vitaly Bulgarov ( vitalybulgarov) • Instagram photos and videos.jpg
The whte pieces i could imagine being created in moi. All the angles look really hard to model in moi especially when you use the orthographic view ports a lot for the boolean operations
Hi Chucky.
@You : screenshot...
Well...I really don't like robots/weapons but clearly Vitaly is a very talented artist.
Technically speaking Vitaly is capable of producing stunning pieces of CG !!!
Chapeau for his talent.
I wonder what kind of pen he uses.
8 )
Hey everyone! I'm fairly new to Moi3D but have been following the tutorials diligently.
I was wondering if you could help me figure something out Vitaly Bulgarov related.
In this post here:
https://www.instagram.com/p/Bq9qyZ5B2V4/?utm_source=ig_web_copy_link
In the first few seconds he does something to create a plane at a very interesting angle in order to trim the top off the leg.
I have been trying to recreate this effect but I just can't seem to draw lines like this without the end shooting off somewhere way off in the distance.
I'm clearly missing something really simple here! Can anyone point me in the right direction please?
Seems
It's just Extrude something (here a simple line) by a Direction! ;)
Helper lines help you to draw the second line (Click move without release...release )
Hi Liam, yes in the Extrude command there's a "Set dir" and if you push it then you can pick 2 points to set up a custom extrusion direction.
Amazing, thanks - having just tested that out, that is EXACTLY what it was.
Many thanks!
Show messages: All
1
2-13
