Show messages: All
1
2-5
Wow that's a lot of them. I'd give the Rebuild command a try:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#rebuild
Oh what a powerful Command!
But in the corners it's not realy useable, cause you get round corners after use.
But, in most cases it's realy well!
Thanks alot.
Hi B-W-Design.
@You : "...But in the corners it's not realy useable, cause you get round corners after use..."
I don't see this problem with curves imported from Affinity Designer. Corners remains corners also after a Rebuild.
Cheers.
Separate for have curves and straight lines separated so you can rebuild only curves! :)
Show messages: All
1
2-5
