Show messages: All
1-3
4-6
Hi Finema.
@You : "...Design your shape (Network or Loft tool)
Apply Multiso script
Select edges and apply a vertical Extrude
Use Shell tool"
Fast and easy! All in less than 2 minutes.
Only with moi is possible!
Cheers.
Message 8632.5 was deleted
Hi Rudl,
as Finema as shown you can use the multiso plugin to create the grid on your surface.
I added another surface to trim the extruded grid to give the depth shown in your photo.
Also I needed to create some new iso lines by projecting lines from the side.
Hope this helps.
Barry
Show messages: All
1-3
4-6
