Show messages: All
1-8
9-16
Wonderfull tool , Karsten -
Many Tanks for info
alberto
Thanks Karsten.
With my poor high school French:
As a curio, my example shows different triangle vs rectangle translations. (Writer was French.)
des triangles rectangles 3D
il est possible de construire
des triangles rectangles 3D sur les deux surfaces précitées.
3D Rectangular Triangles
it is possible to build
3D rectangular triangles on the two above-mentioned surfaces.
(Originally triangles in the above sentence was omitted, so there appears to be some "learning" going on...)
(Right angle triangles via Ring Dupin Cyclides is the subject)
Hello Brian,
could you please send a link to the document- I can't follow you at the moment. Is it a problem with the translator? Maybe you can solve it with a click to the word - then there will displayed alternatives. Maybe Pilou will have a look and switch on the light. The mathematical stuff you are talking about (Dupin???) is out off my mathematical range, but every time a pleasure to see your results.
Have a nice day
Karsten
That can you make! ;)
I made that for a French Text A
French Text A --> English = English Text A
English Text A --> French = French Text B
Compare French Text A & French Text B
Of course take your own native language as Text A!
The 2 versions Native Text A & Native Text B are slightly different but very good!
You can also compare results with
https://translate.google.fr
Don't know I'm testing a couple of Primus song, still don't give any sense at all =0)
Hi Karsten,
There is no problem with the translator, I was just trying it out on a French pdf paper.
<< (Originally triangles in the above sentence was omitted, so there appears to be some "learning" going on...)
Sure it's "Deep Learning" technology ! ;)
From that I see from your example : translation must be!
French original: Des triangles rectangles 3D
Translation
Right triangles 3D (American English) or Right-angled triangles 3D (British English)
But I am not very good in English! But I know how to use the Internet! :)
PS Just a little thing : seems limited to 5000 letters & spaces!
Right on PILOU :-)
- B
Show messages: All
1-8
9-16
