3-21
Karsten your a star,
works a treat better than I had imagined so much adjustment.
It just shows how useful the node editor is.
So again I in your debt.
Many thanks
Barry
No problem - gladly!
Karsten
Very, very nice.
Mike.
Karsten....you rock!!!
What can I say ?
This is one of the coolest node I've seen so far!!!
As a sort of thank you please accept a little video of this simple experiment :
http://take.ms/qEGbZ
Thank you very much.
Ciao!
Marco (mkdm)
P.S. Your last "work" also open a new kind of interesting possibilities!
Thanks!
Hi karsten.
Damn!...how fun it is ??!!!
And it has also very acceptable performance.
This is a video of "section" with a scene made by about 14000 control points :
http://take.ms/G2bww
Cheers.
Animated cut sections indeed!
Hello Marco,
eehm - only a few nodes, nevertheless many thanks for the beautiful video. Maybe others need someday also a section, then no Explanation is needed.
Have a nice day
Karsten
p.s.: A quartz node in combination with a boundingbox for the range would also worth an Experiment. Important is to have fun:-)
Hi Karsten.
You're welcome!
@You : "...A quartz node in combination with a boundingbox for the range would also worth an Experiment..."
Perfect! This is exactly what I've thought while I was playing with this experiment.
An "automatic" range detection would be very very useful.
Is the same approach I have applied to my (almost done) new script "FilterCurveByLength", that I hope to publish soon,
where I calculate automatically the "min" and "max" range for filtering.
Cheers!
Hi Barry and Friends
Without taking anything away from Karsten's instructions, place the same solution
last night I realized ;
Karsten was no doubt much faster ...
This morning I took his post in the forum
file at this link:
http://www.mediafire.com/file/n4dtgc19kwwsf44/Intersect_test.rar
You may want to create a Macro Cross Section
in a very easy way-
have a nice day
alberto
Hello Al,
I saw you have already used the bounding box. That's good!
Have a nice Weekend
Karsten
Hi AL!
Thanks a lot for sharing.
Very cool stuff!
Bounding box is very useful!
Ciao.
Hi Karsten,
thanks for very useful script. I have a problem with nodeditor probably, because if I start latest (v. 0.97) nodeeditor which I extracted after a long time into nodeeditor folder and load the node, so SAVE, APPLY, RUN and STEP buttons become gray and I cannot find out the reason of such behaviour.
Thank ýou for any help.
Mik
Hi Mik.
I've already solved the same issue.
Get this zip archive :
http://take.ms/ayOez
unzip it and copy the whole content into "C:\Program Files (x86)\MoI 3.0\ui\nodeeditor.v.0.97.2017.10.05\nodes\extensions"
or wherever you have the 0.97 version of NE.
You should get this content :
Also ensure that the very last lines of JS code into "index.html" file of 0.97 NE are these :
loadScripts('core','lang, compatibility, colors, geometry, main, editor');
loadScripts('nodes','macros, basic, logic, points, curves, solids, construct, transform, objects, interface');
loadScripts('nodes/extensions/libs','*');
loadScripts('nodes/extensions','*');
loadScripts('core','init, ext.*');
After that you should run all latest nodes without issues.
I solved in this way.
Hi Marco,
this is it! It works perfectly now.
Thanks a lot.
Ciao
M
Why not post the entiere node Editor pakage with the new node ?
I suppose that a Zip file of it takes 2 seconds
It's not ecologic but that avoid any headache of version for the user! :)
If user is interested by the result he copies the .nod in its repository of nodes!
Hi Pilou.
@You : "...It's not ecologic but that avoid any headache of version for the user! :)..."
LOL LOL LOL :)
Want to have fun ? Read all the posts I wrote about this argument (keep things organized, repository, versioning..)
I feel like a voice in the wilderness :)
But...no problem!
I have decided to take it easy ;)
Bye.
You are not alone in the space! :)
Cheers!
3-21
