14-21
Hi AL!
Thanks a lot for sharing.
Very cool stuff!
Bounding box is very useful!
Ciao.
Hi Karsten,
thanks for very useful script. I have a problem with nodeditor probably, because if I start latest (v. 0.97) nodeeditor which I extracted after a long time into nodeeditor folder and load the node, so SAVE, APPLY, RUN and STEP buttons become gray and I cannot find out the reason of such behaviour.
Thank ýou for any help.
Mik
Hi Mik.
I've already solved the same issue.
Get this zip archive :
http://take.ms/ayOez
unzip it and copy the whole content into "C:\Program Files (x86)\MoI 3.0\ui\nodeeditor.v.0.97.2017.10.05\nodes\extensions"
or wherever you have the 0.97 version of NE.
You should get this content :
Also ensure that the very last lines of JS code into "index.html" file of 0.97 NE are these :
loadScripts('core','lang, compatibility, colors, geometry, main, editor');
loadScripts('nodes','macros, basic, logic, points, curves, solids, construct, transform, objects, interface');
loadScripts('nodes/extensions/libs','*');
loadScripts('nodes/extensions','*');
loadScripts('core','init, ext.*');
After that you should run all latest nodes without issues.
I solved in this way.
Hi Marco,
this is it! It works perfectly now.
Thanks a lot.
Ciao
M
Why not post the entiere node Editor pakage with the new node ?
I suppose that a Zip file of it takes 2 seconds
It's not ecologic but that avoid any headache of version for the user! :)
If user is interested by the result he copies the .nod in its repository of nodes!
Hi Pilou.
@You : "...It's not ecologic but that avoid any headache of version for the user! :)..."
LOL LOL LOL :)
Want to have fun ? Read all the posts I wrote about this argument (keep things organized, repository, versioning..)
I feel like a voice in the wilderness :)
But...no problem!
I have decided to take it easy ;)
Bye.
You are not alone in the space! :)
Cheers!
14-21
