Show messages: All
1-2
3-7
Hello Michael,
thanks for your reply! That's much appreciated.
The Hide Button helps a lot.
Quote: "Another way you can select objects contained within others is to use window select - that's where you click the mouse down in empty space and drag out a selection window."
But this way I can never only select the part that is inside the other. If I start dragging in empty space it (of course) also selects the outer part.
Thank you,
Pierre
Hi Pierre,
But that won't be the case when you're doing a boolean difference because the outer part will have been already selected previously and won't be targeted for selection again at this point.
There's a mechanism in MoI called "selection lock" which is used to screen out objects that were previously selected to avoid this type of problem.
Ahhh!
Enlightening!
Thanks!
Hello Pierre,
and there is also a difference in the direction of the window selection: Dragging a window from Left to right selects everything in the box - From right to left: everything in the box and also everything is crossed by the box.
Have a nice day
Karsten
A technique that I use is to name the parts, then I can select from the object pane. Doesn't matter whether the part is visible on screen or not.
Mike.
Show messages: All
1-2
3-7
