13-24
Hello James,
Yep!
It seems that we are missing a Network node;-) And rebuild curve would also help for a complete toolchain!
In a first step we can use a loft for u or for v, but it's not the same!
Have a nice day
Karsten
Hi Karsten.
@You : "...It seems that we are missing a Network node;-) ..."
Maybe I don't remember well, but...Network node had not already been written by someone ?
Hi James,
I can not get a result having followed your instructions.
The node loads ok and runs but no result so not sure if
I'm missing something.
Any thoughts?
Barry
Hi Barry
Try the attached, ensuring that "pretopologize.3dm" is opened prior to loading "retopologize3.nod"
"SelectByName" will auto load surface for re-topologizing.
Hi James,
found the problem when I opened the retopologize macro the IsoCrvs & mPathArray node are in red meaning I don't have them.
So can you post them or point to where they are on the forum please.
Barry
Hi Barry,
Replace nodes/extensions folder with one from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8197.7
It would be prudent to make a copy of existing extensions folder
just in case you need to reinstate it.
Hi James,
sorry still no luck getting the following error message.
Barry
Hi Barry.
I'm running "retopologize" nodes with LATEST 0.97 version of NE and all works fine.
You are running 0.96
Maybe that is the problem.
Marco (mdkm)
Message 8622.21 was deleted
Hello Barry,
it Looks like you don't have basicFunctions.js in extensions\libs Folder.
The additional nodes should work since V0.85 up to now.
Have a nice day
Karsten
thank you all for your answers it's working fine as Karsten said I was missing the basicFunctions.js
Cheers James it's going to be a useful node.
Barry
@mkdm:
Does that method work on full three dimensional objects or only on planes?
May I change mesh in your way (like on your video tutorial) on model like that:
13-24
