Full Version: Writing dynamic UI for Moi's command
2 Oct 2017   [#1]
Hi Michael and everyone.
I have a general question about usage of Javascript in Moi's commands.
I'm trying to improve one of my latest script and I need to make it more "dynamic" and "clever".
For example, let's talk about the command "FilterCurvesByLength" that I have written some days ago (you can find it here http://moi3d.com/forum/index.php?webtag=MOI&msg=8608.4)
The command's UI, inter alia, has two sliders.
Now, I would like that the "max" attribute of these sliders could be set in runtime by Javascript.
I need to do that because is totally useless to have a slider with "max=200" that should specify the upper limit of the range, regarding the curve length,
when, for example, the longest curve is only 100 units.
So, I need to set the "max" attributes assigning to it the value of a Javascript variable.
For example, into the HTML code of the "FilterCurvesByLength" command's page I have this code :
<tr>
    <td colspan=3 id="maxlensliderContainer"><moi:Slider id="maxlenslider" min="0" max="200" style="width:100%" onmousemovevaluechange="doFilter();"/></td>
</tr>
<tr>
    <td colspan=3 id="maxlenInputContainer"><moi:DistanceInput id="maxlen" style="width:6em;" default="1" binding="maxlenslider.value = this.value"/></td>
</tr>
Well. Now I need to dynamycally change the max="200" to assign it a value that I calculated inside the "function init() {...}".
I have tried many ways but nothing worked.
For example I tried something like this :
		function renderPage() {
			maxLengthValue = 20; // I put here this statements only for example. maxLengthValue is calculated inside function init() {...}
			document.getElementById("maxlensliderContainer").innerHTML =
				"<moi:Slider id=\"maxlenslider\" min=\"0\" max=\"" + maxLengthValue + "\" style=\"width:100%\" onmousemovevaluechange=\"doFilter();\"/>";
			return true;
	</script>
</head>
<body onload="renderPage();" class="commandbody">
It seems that after executing that code the binding between the slider and the numeric input field (id="maxlen") doesn't work anymore.
(Assuming that my code at least changes in the correct way the "max=200" attribute of the slider...)
How can I do ?
Thanks for help!
Marco (mkdm)
2 Oct 2017   [#2] In reply to [#1]
Hi Marco,
I'm not sure, but try change outerHTML preperty. Also you can try .replaceChild function.
2 Oct 2017   [#3] In reply to [#1]
Hi Marco, I think you asked this question also on your other thread: http://moi3d.com/forum/index.php?webtag=MOI&msg=8608.5
I happened to see that other one first so I answered it there.
