Show messages: All
1
2-3
Hi Nick, what file formats are you using for the transfer?
For the scaling is there a different active unit system set in Fusion360 than what you had set in MoI ?
One thing to try for rotation is if Fusion360 uses a different axis for the "up" direction, try setting this option in moi.ini :
[NURBS Import]
RotateYUpToZUp=y
You can open the .ini file by going to Options > General and push the "Edit .ini file" button there.
Ah you are right!
I've been using different unit systems
As always Michael, thanks a lot!
Show messages: All
1
2-3
