Full Version: [Help] Extrude/shell How do Is ?
Show messages: All  1  2-3
14 Sep 2017   [#2] In reply to [#1]
Hi Kondou, to do that you start with the surface and then a 2D profile curve that you've drawn in one of the 2D Top/Front/Right views which is over top of it in that view. Then you use Edit > Trim to cut the surface with the curve and leave all the pieces behind. That will then make a separate face that you can extrude or shell as shown in your linked video.
There are some examples here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3024.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=4010.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=3318.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=4791.13
Hope that helps!
16 Sep 2017   [#3] In reply to [#2]
Michael Thank you, is Work good job!
