Hi all,
Trying to create a shape similar to this have had various levels of success wondering if any Master Modellers have any pearls of wisdom on approach methods.
Have tried blended lofts and subD skins
Hi AlexPolo
I've seen this art piece in the past, but never figured out how to do it.
A few years ago I saw it with a red face, and another color face, I think on an artist's site.
There were a few more view angles.
This recent post may be of help. The basic shape of the holes is that of parabolic cyclide, two parabolas
with vertices passing through each others focus, with different size circles ( or spheres) centered on them, and lofted/swept.
http://moi3d.com/forum/index.php?webtag=MOI&msg=8576.5
Do you have a link to the page with the art?
Thanks for link will delve into it here is link to artists site.
http://www.bridgesmathart.org/art-exhibits/jmm09/friedman.html
There are 3+ views of the carved 10" X 6" limestone, of carved wood here:
http://breezyhillturning.com/Minimal-surfaces/minimal-surface-turnings.html
Copy of paper by professor Nat Friedman:
http://math.unipa.it/~grim/21_project/21_charlotte_FriedmanPaperEdit.pdf
Note that the soap film, figure 3d, has two holes with two surfaces, and the same trefoil knot is shown in figure 7c,
as a two hole knot, which is formed by manipulating the one hole, one surface, trefoil knot of figure 7a.
I have not found a surface evolver model yet.
There is a tinfoil model of the knot here, as well as 1/4" copper wire.
http://t.archive.bridgesmathart.org/1998/bridges1998-139.pdf
So making such a trefoil knot in wire, and dipping it in soap and glycerin, popping the two holes,
should give a physical model...
Surface evolver is the other option...
The program for surface evolver, for a different sculpture, between an unknot and a trefoil, is explained here:
https://www.thingiverse.com/thing:1559227
Looks like a mirrored version of Jotero's Yin Yang. :-)
http://moi3d.com/forum/index.php?webtag=MOI&msg=5529.1
Hi Stefan!
Wanderful model! Could you post the 3dm ?
Sorry Marco, better not...
Best regards
OK. No problem.
Bye.
That is the one I half remembered, only 5 years ago!
Time to try again...
As far as I know, there is not a .3dm available.
The front view and the left view are symmetrical.
Hi All,
Thanks for the leads cant believe the historical trail needles in a haystack falling in the same pile - MOI a great forum with a diverse range talents!
Will digest posts contained.
Best regards
IMHO, the "yin-yang" is a seifert minimal surface on a trefoil knot.
Using the flat crossing knot diagram of the trefoil knot, showing two holes, the "braid" type,
there is a procedure to make a seifert surface by replacing the crossings by bands rotated 90 degrees.
Unrotating the central band orients the two holes to 90 degrees, and the flat surface becomes 3D.
