Show messages: All
1-2
3-8
Hi Mik,
> It would be perfect to find standard Export dialog window after selecting parts and run
> the script, where it can be chose save location and format.
The problem here is the standard Export dialog window is focused on picking a file name. But this script doesn't write to a single file name, it uses object names as the file names. So if the standard Export dialog was to be shown, the name you entered in there would not actually be used.
For additional formats, I think if you modify the list in ExportParts.htm it should work. It currently has this:
<option value=".3dm">3dm</option>
<option value=".stl">stl</option>
<option value=".obj">obj</option>
Try adding to that list like if you want STEP and IGES formats put it in like this:
<option value=".stp">STEP</option>
<option value=".igs">IGES</option>
it works!
Thanks a lot!
Mik
Hello,
Very uselful script for me when i have to export 3d model with "50 parts" from a customer order.
1) How could i choose the file folder export ???? (impossible to understand in which folder the files go (or it doesn't work) !!!.
2) Is it possible to have an .skp export ?
3) How could i add the java program code line to have more export pmossibilities ??
Pierre
Hi Pierre,
For this particular script you have to open the file ExportParts.js and edit line 5 which currently reads:
var pf="/Users/username/Documents/CAD/"; //change this path to your needs!!!
The path that is in there currently is a Mac path, for Windows you'd need to to use \ backslash characters and then the tricky part is you actually need to use 2 backslash characters \\ for each one because in JavaScript strings the backslash is an escape character to make stuff like \r meaning return or \t meaning tab. So on Windows you'd make it like this:
var pf="c:\\ExportPartsDir\\";
Yes it should be, you'd need to add an entry to the file type dropdown which is in the ExportParts.htm file, similar to what's described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8582.3
For SKP format add another line like this:
<option value=".skp">SKP</option>
It has to go in the ExportParts.htm file which is the UI part of the script, you need to add more entries to the select dropdown in there.
Please let me know if you're still stuck.
Thank you Michael. Im going to try.
Regards,
Pierre.
Thank you Michael for answering the questions to my script!
I was in holiday... :-)
But all you answers have been RIGHT! ;-)
THX
Ralf
Show messages: All
1-2
3-8
