16-23
Hi Chipp .
Sorry to try to contact you via this forum
I read an article written by you recently and wished to ask you some questions about software
I can't find the thread.
I am reachable at
eric@ericdesignstudio.ca
If you have the time and inclination please send me a contact method
thanks,
eric
In 3dC, during import object, select "W/O voxelization".... This will import separate named objects on their own layers... You can then voxelize layers 1 by 1 if you want voxels.... This is good too because you don't always want "4 million polys" to get detail on a box", like you may need for a blob of some sorts... Each object can have it's own poly count settings...
Hi Marco
Do you know why the Rocket forum has gone quiet? I want to know how to constrain extrude to 90 degrees but there seems to be nobody to ask.
Best wishes
Keith
@ BurrMan @keith1961 I hadn't checked "Import w/o voxelization" nor "Import to separate instances". I've just tried with another model and it works!! Thank you guys!!!
Hi keith1961.
@You "...Do you know why the Rocket forum has gone quiet?..."
Good question. Also I'm wondering...
I'm going to echo this question also on NVIL's forum that is managed by Istonia (the creator of R3F along Samardac)
@You : "...I want to know how to constrain extrude to 90 degrees..."
What exactly do you mean ?
If you're talking about "Normal Extrude", this is very simple in R3F.
"Normal Extrude" in fact already extrude a face or a group of faces to 90 degrees.
It's very simple.
1) Pick the face(s) you want to extrude
2) Hit the "a" key
3) With that key pressed push the middle mouse button and start to drag (you can also release the "a" key after you have started to drag)
4) release the middle mouse button when finished
And in this way you can perform a "extrude normal".
Bye!
Hi Marco
Maybe Samardac is on holliday?
Ah... the 'A' Key i was trying shift, space, ctrl
Hi keith1961.
You're welcome.
@You : "...Maybe Samardac is on holliday? ..."
LOL :) I don't know...I don't live with Samardac :)
Anyway I asked on NVIL's forum about the silence of R3F's forum.
Bye!
16-23
