Show messages: All
1-3
4-9
True, no image loading. I recalled the post because it dealt with images, and might be helpful if someone were making a load script.
Images.htm and Images.js are the two existing scripts in MoI.
I am not aware of an automatic Image load script.
I think a good question would be what sort of layout or alignment do you require.
Assuming some sort of repetitive task, a couple of examples might be:
1. Up to six images, one each for: Front view, rear view, left view, right view, top view, bottom view.
(Say to trace out images of some model.) (set up as a "cube", or rectangular 3d box.)
2. Several images laid out checkerboard fashion.
So what would the predetermined alignment parameters be?
I do not know if the Batch Processing script would be relevant. Something to study.
http://kyticka.webzdarma.cz/3d/moi/ (near the end)
Hi track, I think it should be possible to do a scripted load of background images, but like Brian writes above it would also need to decide the placement of the image - what plane it's on and its bottom left and top right corners. How would you want the script to handle those parts?
I succeeded to place an image in a given position in 3D with the property frame of the image object.
I will look at the script mentioned above
Hi track, the function AddImage() in commands\Image.js is how MoI's image command creates new images. But it's a little complicated since all the UI and pointpicker bindings and such are in there as well.
Here's a streamlined example that just uses some fixed parameters:
var filename = 'c:\\img\\test.jpg';
var baseframe = moi.vectorMath.createTopFrame();
var cornerpt = moi.vectorMath.createPoint(20,20,0);
var factory = moi.command.createFactory( 'backgroundimage' );
// background image factory has 3 inputs:
// 0 : String - FileName
// 1 : CoordinateFrame - Plane that gives orientation of bottom-left corner of image
// 2 : Point - upper-right corner point.
factory.setInput( 0, filename );
factory.setInput( 1, baseframe );
factory.setInput( 2, cornerpt );
factory.commit();
Hope that helps!
Message 8571.8 was deleted
It works
Show messages: All
1-3
4-9
