Hey guys
I've been attempting to model this geometrical object as shown in the video. Twisted Torus
https://youtu.be/3_VydFQmtZ8?t=581
I'm interested in hearing your oppinion about what approach you think would be the best
Tradional modelling or some sort of script perhaps?
Nick
Message 8510.2 was deleted
I was able to model the two piece bagel, made with straight line segment knife, rotated 360 degrees,
using center axis of torus unwrapped as base line for flow. The unwrapped line is also the center line of two one-turn helices with one rotated 180 degrees.
The line segment knife is swept along the two helices as rails. The sweep is the source for the flow.
The center axis is the target for the flow.
Next the torus and swept knife were divided into 4 quadrants, using circular array, because otherwise trimming doesn't seem to work properly.
Each quadrant is trimmed by the quadrant of the swept knife.
The swept knife quadrants were trimmed by the torus quadrants, to make the face where the cream cheese goes.
Appropriate parts were colored and joined, to make 2 interlocked solids, as per the first part of the video.
Maybe tonight will try the other models...
Hello,
I will probably use twist and flow for this (hoping I really understand the concept).
However the final fillet need to be done in Fusion.
Hello,
Actually the twist angle should be i*360 + 180 ... here's the 540 degree version.
The toroidal helix script of Michael can be modified to produce (at least some of) the cuts.
The number of turns must include fractional turns, like 1.5.
Also negative numbers may need to be entered for one or both of the two radii to get the correct handedness.
Had to run the mod script a couple of times with different +/- radii...
Well, it is late, and needs more investigation...
Message 8510.7 was deleted
Message 8510.8 was deleted
Respect , thats a creative use of MOIs toolkiet !
PaQ can always pull a rabbit out of his hat....
I wish to be a fly, buzzing around that monster!
Hey!
(Sorry about the slow reply, totally forgot about posting this question)
Thanks alot for taking the time. And PaQ, thats one hell of a solution. Thanks so much for this, lovely :)
