15-27
Hi.
I used this script which exporting all objects to AI* files, but all objects (fit to page). I used 3d viewport.
I think it will be good idea if it exporting each object + one test object( named "scale") maybe just line or rectangle.
This will allow the save scale of the objects relative to the test object and to each other
Could you help me to add this function to script?
Hi Anton, are you exporting a 3D perspective view? Because if so the length of a line with perspective applied will not be able to give a scale factor like that.
Please check my images maybe it will be more clear.
Thanks.
Hi Anton, so if I understand right you want the line to establish a common page width?
Is the script you are using the "ExportNamedObjectsToIndividualFiles.js" from above in this thread (
http://moi3d.com/forum/index.php?webtag=MOI&msg=8226.8) ?
Do you want something like the line has a certain name and the script will export that additionally to each file?
So in the script ExportNamedObjectsToIndividualFiles.js, on line 36 it has this currently:
for ( var name in named_objs )
// Clear the selection and then set all objects of this name to be selected.
moi.geometryDatabase.deselectAll();
named_objs[name].setProperty( 'selected', true );
So if you want the line to export with each file, it could go like this:
// new code here:
var line_name = 'reg_line';
if ( name == line_name )
continue; // Don't export the line all by itself.
// select the line so it will export.
if ( named_objs[line_name] )
named_objs[line_name].setProperty( 'selected', true );
I haven't tested that, let me know if it doesn't work.
Sorry but it is not working.
Probably just I am not good java developer.
I am getting all 3 objects (1,2, line) as separate files
Thanks for your help again
Hi Anton, can you please post the current script you have and an example .3dm file ?
Yes sure.
And sorry for my incompetence
ExportNamedObjectsToIndividualFiles_test.js
test.3dm
Hi Anton, try this attached one, and also the script is expecting the line's object name to be "reg_line" but in your .3dm file it is named "Testline".
I still didn't test this so please let me know if it still doesn't work and I will take a closer look.
Oh thanks man. It is realy working.
How could I thank you?
I am illustrator and if you need something to draw let me know.
(yaberezinanton@yandex.ru)
Hi Anton, that's great!
It would be fun to see some of the output that you're using it for! :)
I’m trying to create method to export a complex illustration\model as different parts\files for further processing and assembly in Adobe illustrator.
I will show you the result
Thanks again
Hey Michael,
How can I make ExportNamedObjectsToIndividualFiles work for
STEP [(*.stp, *.step, *.stpz) (AP 203, AP 214, AP 242)] ,or
SAT [(*.sat) (Up to 2020)] Files?
Also, my target app, Alibre Atom3D, accepts only one Solid per file.
This script will write out every object having an identical name to the same file.
Might it append a numeric incremental for each such duplicately named solid and thereby save it into its own separately named file?
Another problem is that it will write out a group, rather than just its individual constituent solids.
Also, might the user pick the output directory at runtime ?
MindSet
Hi MindSet,
Are you using the ExportNamedObjectsToIndividualFiles.js that was in this previous post? :
> How can I make ExportNamedObjectsToIndividualFiles work for STEP [(*.stp, *.step, *.stpz)
> (AP 203, AP 214, AP 242)] ,or SAT [(*.sat) (Up to 2020)] Files?
MoI will figure out what file type to write based on the file extension on the filename.
So to make it export STEP instead of FBX, go to line number 43 in the script which has this currently:
var filename = g_dirname + name + '.fbx';
And change the .fbx to .stp like this:
var filename = g_dirname + name + '.stp';
I've attached a version that should do that.
This should be fixed in the attached version also.
Sorry no that's not easy to do currently because there is not a directory picking UI set up for a script to use. I'll see what's involved in setting one up.
15-27
