Full Version: PBR pipeline for MOI3D using 3D COAT and KEYSHOT
 26 Sep 2016
To: ALL
Spent some time this weekend figuring out how to UV Map MOI 3D models, add PBR textures, and then transferring the maps and model to KeyShot for rendering.
KeyShot is not a PBR renderer, but you can trick it to use PBR maps.
Sorry the video kinda bops around a bit-- I don't know 3D Coat that well yet.
Reply
 26 Sep 2016
To: ALL
Hi chippwalters,
Wow, even though it's your first test involving Moi + 3DCoat + Keyshot, I must say that it's a very very good result!
I'm an enthusiastic user of 3DCoat and I'm glad that you are trying to include it into your current workflow.
Moi + 3DCoat = Easy and fun!
Ciao and have a nice day.
P.S.
1) For simple purposes or in order to quickly show rendered prototypes, also 3DCoat's internal renderer it's very good.
2) Instead using 3DCoat Paint Room's fill tool and click on every part of the object that you want to paint, you can RMB click on Smart Materials Preview
and click "Fill Whole Layer". Only, just check if you are on the right layer into the Layers tab.
3) I noticed that for the 3 different parts of the base, you painted using the same layer (base).
I suggest you to use a more Photoshop-centric style. That is, paint different features on different layers, in order to better control the final results.
Reply
 26 Sep 2016
To: ALL
Looks really sexy chipp !
Reply
 29 Sep 2016
To: ALL
Chipp, whats your thoughts on this method for REALLY BIG assets for film?
I just completed an asset that was 50 million polygons entirely in Moi. I had the split the asset up into a dozen differnt files to complete. Because the asset is so huge, it would require a large number of 8k texture maps. I only had about 7 days to do the entire texturing so I didnt want to test 3d coat for this because I wasnt sure of the look that I would get.
Reply
 29 Sep 2016
To: ALL
Couple of thoughts.
It's hard to predict the results. I don't think the 3D Coar paint room is set up for models with that many ploys, though it may be worth trying. Also, I don't know that you need to use 8K maps for a large scene.
MeshLab has some great poly reduction algorithms, though I suppose the best way to reduce ploys is in MoI.
I suspect most 3D paint programs will choke on 50 million polys. What is/are the model(s) you're working with?
Reply
 29 Sep 2016
To: ALL
I am under NDA...but it is a 1500m concept spaceship for a well known space agency. So you can imagine the scale, and the detail needed (i modeled even the windows).
I was thinking of just importing sections and texture that. The renders are 6k and closeup so i need the high resolution. 50m polys sounds like a lot, but the geometry is pretty lightweight, because it iss solid surfaces there are a lot of hidden polygons that could be deleted.
Reply
 29 Sep 2016
To: ALL
<< 50 millions
Seems Zbrush can manage this sort of number of polygons! ;)
Just have some free memory and hard disc free place :)
Reply
 29 Sep 2016
To: ALL
Hey 2byts,
Can't you go with a more procedural texturing approach ? using fractal noises (or other noise flavor), occlusion mask, convex edge shader, maybe tri-planar textures, texture bombing etc.
Because hand painting something that huge might take a lots of time.
What kind of auto uv unwrapper are you planning to use ?
Reply
 30 Sep 2016
To: ALL
That is exactly what I decided to do, which means a great deal of complex shading networks. Redhsift was required for this renderer, so I did have limits on the depth of the shading network.
When working with TriPlanars, UVs are not being used anyways, so I only used UVs on specific areas instead of the complete model.
Pilou, Zbrush can handle 50m polys no problem I am sure...but this was an optimized export from Moi so the topology was useless for sculpting or vertex painting. If I used settings that Zbrush would need, then the asset would easily be 1 billion polys. Working with such dense assets needs a proper pipeline which I didnt have the time to setup. The challenge is working with a 1500 meter asset that gets viewed up close with a 6k render! I never worked on such a huge asset before, and I would never be able to do it without using Moi on 95% of the asset.
Thats why I found 3d coat interesting because it can take the UVs from Moi and do a layout on import.
Reply
 30 Sep 2016
To: ALL
Hi 2byts,
I read your posts very carefully and it's a very interesting thing to know that Moi can help also in this extreme situations,
thanks to its great exporting capabilities.
I absolutely have no skill regarding so complex projects, but as far as I know, unless you don't have a limitless budget,
3DCoat actually is maybe the best solution for that type of UVing and 3D painting.
I suppose that this choice requires, of necessity, a big amount of work in order to "break" the whole project
into smaller pieces, easily digestible by 3DCoat...
Anyway...thanks for your sharing and best wishes for your work.
P.S. If you can, if it doesn't violates copyrights, could you post some screenshot of the project you are working on ?
Have a nice day,
- Marco (mdkm)
Reply
 30 Sep 2016
To: ALL
FWIW,
I was able to import for texturing in the PAINT room a 5.1 million poly OBJ on my little weak Macbook with only 8 Gb memory and crappy 1.2 GHz Intel Core M
The Paint room is where you can AutoUV your models and apply smart materials, which would be pretty great. Good luck!
So.. I would think it would work for a more powerful machine. :-)
Reply
 30 Sep 2016
To: ALL
Hi chippwalters,
3DCoat is great!!
I hope that you are going to do some interesting tutorials regarding the workflow between Moi and 3DCoat.
I think that it would be very helpful for many people (and for me). ;)
Nice day,
- Marco (mdkm)
Reply
 1 Oct 2016
To: ALL
Hi 2byts,
I hope you will share the end result one day !
Reply
 2 Oct 2016
To: ALL
i hope i get permission!
Reply
 4 Oct 2016
To: ALL
Hope I'm not overstaying my visit, as this post will mostly be about 3D Coat.
Consider this object (click to view larger)
It represents the start of a robot hand, sculpted in 3D Coat in about an hour. I've been playing around with 3D Coat lately, and I find I can sketch with it like I do in Photoshop. Don't get me wrong, the quality of the final model is quite suspect, and I couldn't use if for finished client design work (I use MoI3d for that), but I could use it for preliminary concept work and quite fast I think.
I'm still trying to learn the program. Voxels are a completely different paradigm that what I'm used to and just like coming from Polys to NURBS, you have to 're-think' your modeling strategies. One of the nice thing 3D Coat has is instancing, which allows me to work on one finger and have them all update, not unlike SketchUp. The other thing about 3D Coat and ZBrush is they have a certain 'look' to them. "Uncrisp" if that's a word.
FWIW, I bought and watched most of Jama's Intro to 3D Concept Design tutorials. He's quite the talent, and really does work 3D Coat magically, but unfortunately he's really weak on actually teaching the basics of what he's doing. He misses a lot of steps and doesn't explain very well HOW he does things. Still, it is very inspirational to watch him work and I do think he put a lot of thought into his workflows. He's just weak on technical stuff and especially explaining technique. All said and done, I still think I got $100 value from watching him work-- so no complaints. I may do some 3D Coat modeling tutes when I get better and understand the process better.
Reply
 4 Oct 2016
To: ALL
Yep voxels are funny things! (a 1*1*1 cube(s) of pixel :)
they are apparent inside 3DCoat and editable!
they are hidden inside ZBrush! (some functions use them but transparent for the user! ;)
Reply
 4 Oct 2016
To: ALL
Hi Chipp,
i do have 3DCoat (edu) too and have read that switching from Voxel to Surface mode is the way to go, when finalizing a model. I do think also that 3DCoat does not have the crispness and models looks mostly woobly compared to those sharp sculpts seen from ZBrush. But i will test this when i have obtained my copy of ZBrushCore.
Reply
 4 Oct 2016
To: ALL
Hi chippwalters,
And thank you very much for sharing your progress in 3D-Coat learning!
Much appreciated!
And I like your hard-surface style. (although I must admit that I'm not much for robots and weapons in general...)
Over the past few weeks I spent much garbage time to dig into 3D-Coat and more I use it more I understand how smart is this software.
Yes, it's true that, for the moment, the polished and crisp results achievable with ZBrush 4R7 modelling arsenal are undoubtedly better than 3D-Coat,
but admittedly it depends very much on the skill level of the artist (and I'm not very skilled...)
Talking about ZBrush Core vs 3D-Coat, I think that the debate is worthless.
3D-Coat Amateur version costs around 100$ and offers all the tools of the standard version :
Voxel, Surface, Boolean, UVing, Texturing, Painting, Baking, Retopo, etc, etc...
So...3D-Coat beats Z Core 10 to 1!
Anyway, I think that if we strictly talk about modelling tool-set, although 3D-Coat Voxel’s are a Swiss army knife,
the power and versatility of ZBrush’s bushes and modelling tool-set is actually unreachable.
If you haven't already done, let's take a deep look to the official youtube 3D-Coat channel (https://www.youtube.com/user/PILGWAY3DCoat/playlists).
There you will find a huge amounts of tutorials on almost every aspect of 3D-Coat.
Thanks again and have a nice day!
Reply
 4 Oct 2016
To: ALL
Hi futagoza,
Yes, this is a good workflow in 3D-Coat :
1) A first and coarse model, done in low/mid voxel density
2) Using voxel tool-set, especially boolean tools.
3) Increase the voxel's density while modelling details
4) Switch to surface mode + Live clay brush for the finest details
Nice day,
Reply
 4 Oct 2016
To: ALL
I'm still using mudbox so very interested in 3D Coat and how well it generally works for retopo, UV, painting, modeling. Love to see your and other vids on that Chipp.
Funny, I'm able to get pretty good models that are organic out of mudbox and feel it's a descent tool but it's obviously way behind Zbrush and other sculpting specific packages these days. However it's pretty fast and works pretty well. It's not very good at making hard surface sculpts however so I use moi for that specifically and Maya.
Reply
Show messages:  1-20  21-40  41-60  61-80  81-95
Reply to All
Back to thread list | Login
© 2018 Project Beehive Forum
