Best of the 2 worlds is cool, but it's even better when both approach co-exist in the same application.
T-Splines, and Cyborg3D for instance have some very nice functions that mix curves, nurbs surfaces, and subdivision surfaces.
Caging NURBS is a great way to go for those that like to push and pull.
It gives you the ability to "monitor" what doesn't really JIVE with a NURBS surface and what's working.
So you can finish all the bending and twisting while NURBS, then go out to poly and not bring it back!
Oh yes....T-SPlines is a great thing and, although Fusion 360 has a downgraded version of it, it's very useful and powerful when properly used.
And yes, I already knew and in my recent past I've used and experimented a lot with Cage/CageEdit in Rhino V5/V6 WIP.
Also these tool are very powerful in some situations.
But, for what I want to experiment and create in this period, I think that the agility and and easy of use and the speed of working
directly with mesh's vertices/edges/polygons can give me a very good and fast way to create good organic modelling with SDS,
because, when properly used, this technique can offer a degree of freedom that actually can't be reached by T-Splines or other pseudo-Nurbs
technology.
Nowadays, for what I know and I have read, Poly/SDS is still the best and fast and easy way to freely model organic things.
Many engineers and software houses have invented their own technology to make possible the "marriage" between Nurbs and true organic modelling,
for example SolidThinking Evolve and many others (T-SPlines, Clayoo) but for what I have read in many technical articles written by many experts,
all these technology for the moment, are incomplete or too heavy, and still the "plain and dirt" Poly/SDS approach is still the best.
But anyway all these stuff are very interesting things.
Hi
I just discovered how to get from a low poly object from Moi to a highpoly surface in 3d Coat ready to retopo. I made a video. Hope it helps someone:) https://youtu.be/dJn0ROIzMhM
Keith
- Free.
It is absolutely fully functional version but it is based on subscription that you have to renew every month, also it has small banner and you can not use it for commercial work. https://rocket3f.com/component/osmembership/free/free/sign-up :Get it!
- Basic, 55 EUR.
It is full version of Rocket 3F except you can not: customize it, change hotkeys, customize UI, create your own tools etc, you just use it how it is. This version is best for Beginners, Concept Artists and other persons who do not want to spend time customizing Rocket 3F, you have everything you need right out of the box! https://rocket3f.com/component/osmembership/paid/version-1/sign-up Get it!
You can try to get it for free here! https://rocket3f.com/blog-news/73-get-rocket-3f-for-free
- Pro, 160 EUR.
It is a flagship version of Rocket 3F, you can customize it the way you need it, you can change hotkeys, create your own User Interface, create your own StreamLine and Composite Tools, create your own Radial menu, etc... you can change everything!
Coming soon!
- Corporate, 260 EUR.
It is Pro version but for Companies that perform some business.
Coming soon!
Configurable version! (not for the Free version still existing! )
- Manipulator was added
- One and Four Views was added
- Ortho view was added
- Network tool was added to Splines
