C4D has good enough render. Yes I want render, but not for a price of CAD+rendering. I would be happy to buy also Keyshot, but in this moment I could buy or moi3d+another rendering software and have some money for living or buy Keyshot and die from hunger. For this reason I asked for an alternative and for this reason I explained what I need. Is it clear?
PS: Keyshot HD sucks. I've got no any idea who pays for this toy.
You have pretty good renders engines inside Blender who are entierely free! Blender too!
The only cost is the learning curve who is not so evident for my old brain! :)
So I prefere Fusion 360 (free for enthusiast,hobbyst, student, even StartUp ! http://www.autodesk.com/products/fusion-360/try-buy
who has a render like a sort of an easy Keyshot for mecanical volumes or other crazzy forms! Life is too short! :)
And works very fine with Moi :)
I have gone through the same process of looking for rendering software that will accept non-mesh style formats like STP. I don't like the hassle of exporting to a different format and uploading to the cloud for file storage, but Fusion 360 can be acquired for free if a user earns less that $100k using it commercially. It has a decent enough render engine and a user can get something right out of the box, so to speak.
please, don't offer me Keyshot. I don't have money for Keyshot, Keyshot is too expensive for me, I don't have a job to earn with Keyshot, so, please, don't offer me Keyshot.
Not "offering" you KeyShot-- just correcting the perception you can't do soft lightbox lighting effects with it.
If I were you, I'd look at Marmoset and collect some standard HDRIs which already have the soft lighting you want. Also, because it's PBR shading, I suspect it would be simple to create a soft lightbox object(s) which you could easily drag around. Just create a plane and either give it a diffuse soft map or make it white and add a soft transparency map and set the material to emissive and voilà, you have your soft lightbox.
Keyshot HD won't create, edit and place. you can use presets only and this is completely useless. Keyshot PRO has all needed features, but the price is too high for me and I wrote about this
Hi Dzeko, you might try saving to PDF, AI, or DXF formats, those will generate a 2D drawing using edges and silhouettes of the NURBS model.
For rendering programs the standard way for renderers to work is to convert surfaces into triangles and then render the triangles. With a renderer like that you might be able to get a better looking wireframe though by exporting out from MoI using N-gons instead of triangles which will preserve more of the original edge structure of your object, and also if you export with "Weld vertices along edges" turned off some renderers have a "toon" mode which can put outlines on the open edges which will correspond to the original edges in your NURBS model so that's another possibility.
