Show messages: All
1-4
5-9
Updated epicycloid speed reducer .nod file to work with Nodeeditor version 0.95.
Added the frequency input to Quartz, and adjusted the frequency (speed) setting downwards considerably.
Looks pretty smooth at a low RPM, and a jitterbug at higher RPM :-)
The output shaft is missing, not to mention bearings...
Had to redo the 4 math nodes, went from blue wires to teal blue wires. (The prior node had 14 downloads.)
Hi, Brian.
Not quite working properly for me - lots of clashing of parts.
No time to explore further for a while so will report back later.
Mike.
Hi Mike,
yeah, something is out of whack.
It was working perfectly, but when saved, it must be "out of phase."
OK, here is the .zip file of the corrected .3dm of the gear, along with the .nod.
When I saved the .3dm from MoI, after having run and stopped the .nod,
the .3dm of the gear was not in its starting position.
Lesson learned.
CycloidGearEpi.zip
Thanks, Brian.
Mesmerising and wonderful.
I look forward to studying the nod.
Mike.
Show messages: All
1-4
5-9
