Show messages:  1-10  …  931-950  951-970  971-990  991-1010  1011-1030  1031-1050  1051-1070  …  1851-1859
19 Apr 2018   [#991]
Where can someone find a step by step tutorial of how to use the node editor? Any link somewhere?
19 Apr 2018   [#992] In reply to [#988]
AMAZING JOB!!!!!!!
Period.
19 Apr 2018   [#993] In reply to [#988]
P.S....
James, where can I find the retopoSurfs node ?
19 Apr 2018   [#994] In reply to [#993]
Hi Marco,
Place the attached file into directory
~/Library/Application Support/Moi/nodeeditor/macros
19 Apr 2018   [#995] In reply to [#994]
Hi James.
Thanks, but...where is this folder ? "~/Library/Application Support/Moi/nodeeditor/macros"
I have a Windows machine and my folders for Node Editor are :
1) For Moi V4 : C:\Users\<user name>\AppData\Roaming\Moi\<node editor folder>
2) For Moi V3 : C:\Program Files (x86)\MoI 3.0\ui\<node editor folder>
Any help ?
19 Apr 2018   [#996] In reply to [#995]
Hi Marco,
Sorry the directory path was for a mac.
So rather it would be (for Moi V4)
C:\Users\<user name>\AppData\Roaming\Moi\nodeeditor\macros\retopoSurfs.nod
If there is not already a "macros" folder, make one.
Let me know if this doesn't work. I don't really know my way around PCs
19 Apr 2018   [#997] In reply to [#996]
Thanks a lot James!
I've tested in V4 and it works :)
Does it work also with the latest Nodeditor for MoiV3 ?
19 Apr 2018   [#998] In reply to [#996]
P.S.
I've made some experiment....what a wonderful Swiss-Army-knife for some situations where I simply want to turn a single surface to ALL QUADS!!!
Thank you very much!!!!
19 Apr 2018   [#999] In reply to [#988]
Hi James,
just tried to run nod on half sphere surface and just a tangled result.
Are there any restrictions on what surfaces the nod can be applied to.
Update once surface goes wrong all following selections go wrong as well
even those that previously worked correctly.
Barry
19 Apr 2018   [#1000] In reply to [#999]
Hi Barry
<< Are there any restrictions on what surfaces the nod can be applied to.>>
Yes, it will only work with 4 edged surface patches.
<< just tried to run nod on half sphere surface and just a tangled result.>>
This is a difficult one because you can't start with sphere solid, because it won't work with trimmed surfaces.
Attached is method for retopologizing a 3 edged hemisphere made by networked curves.
19 Apr 2018   [#1001] In reply to [#1000]
Hi James,
Ok that’s good will stipulate the 4 edge requirement in my other post.
However the concern I have is once a surface that does not meet that
requirement causes the macro to crash and the following correct
surfaces also crash.It would be good if a reset within the nod was possible.
The only way I see to reset the nod file is to close and reopen Moi ?
Anyway thanks for your help I think your macro is well worth developing.
Only wish I had the knowledge to be more help.
Barry
19 Apr 2018   [#1002] In reply to [#1001]
Hi Barry
Can you send me the .3dm file so that I may reproduce the error
and perhaps find a work around.
19 Apr 2018   [#1003] In reply to [#1002]
Hi James,
I'm using the file I posted(http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.987)
Just added a sphere and trimmed it on it's seam to make a dome surface and named it S8.
From the photo you can see the tangled result of the dome and when S7 was next applied
you can see it is also wrong.
I noticed the surfaces spike to drawing origin.
Barry
26 May 2018   [#1004]
Hi All,
I feel nodeeditor has been neglected, so this weekend I decided I would play around with it.
Below is an unintended result of that play.
The other attachments are also outcomes of the same nod circuit:" surfTria.nod".
Have a great weekend
26 May 2018   [#1005] In reply to [#1004]
Hi
How it works ?
26 May 2018   [#1006] In reply to [#1005]
Hi Finema,
>> How it work <<.
I doubt this will be satisfactory, but the short answer is as follows:
Set up nodes to create base surface tesselation of hexagons, each lofted to a centre point to make triangular tiles and flow to target surface.
The underlying hexagonal pattern is variable in row and column , While the triangles are height variable of ctr.
Hope this helps
26 May 2018   [#1007] In reply to [#339]
Cool!
27 May 2018   [#1008]
Some further development based on previous nod file
27 May 2018   [#1009] In reply to [#1008]
Hi James
Can you share the 3dm file and the library used in your nod ?
Thanks a lot
27 May 2018   [#1010] In reply to [#1009]
Hi Finema,
>> Can you share the 3dm file <<.
The nod file works on its own, without input curves or the like.>> .....and the library used in your nod ? <<.
I take it by "library" you mean my "Extensions" folder of node editor. Please find attached.
Also ensure that you are using Max's most recent NE: can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.608
If you mean something else let me know.
Hope this helps
PS I update nod file in my previous post, which should generate quicker, albeit still approx 20 secs.
