Show messages:  1-3  …  924-943  944-963  964-983  984-1003  1004-1023  1024-1043  1044-1063  …  1844-1859
13 Mar 2018   [#984]
Marco thanks for the nice words..
and for the video you made as a service to all nodeeusers ...
Thanks again
Have a nice evening
alberto
13 Mar 2018   [#985] In reply to [#984]
You're welcome Alberto!
If I may, let me give you only one little suggestion, that maybe you already know.
If you want, you could post a simple capture of Moi's screen with some, or at least, one use case of the wanderful nodes you're post here from time to time.
In this way it's easier for any user to get a quick look of what that particular node does.
And also the user is "encouraged" to download the stuff and play with it.
My two cents :)
Thanks for all your wanderful nodes!
Ciao.
12 Apr 2018   [#986]
Hi Friends
I want to share this Macro with you,certainly useful I Hope
M_Pipe
input:
-curves
-radius
- cap round =0
- cap flat = 1
If the input curves overlap the result
it is only one Brep-
file at this Link :
http://www.mediafire.com/file/wqnulsmi5hn2m3b/M_Pipe.nod
have a nice evening to all
alberto
18 Apr 2018   [#987]
Hi I need some help (as usual),
I'm using James Retop nod to generate the facets for Sub D smoothing as the Zarkow method.
I create surfaces and name them.Then using the 'get by name' selector step thro them one by one
adjusting Iso 'u-v' as required and applying the faceted results.
however sometimes the facets are connected out of order (see photo's) usually in the Iso 'u' direction.
however if I rebuild the surface (unnamed) it works correctly.
I'm using Max's latest nodeeditor and have attached Surfaces and nod files.
Barry
Retopo Surfaces.3dm
RetopoSubD.nod
Screenshot (12).png  Screenshot (13).png  Screenshot (14).png  Screenshot (15).png
18 Apr 2018   [#988] In reply to [#987]
Hi Barry,
I'm sorry about this bug in my macro. I have encountered this issue before with a similar macro: "Surface&Tile", and attempted a work around. I have pared back said macro and included it in attached .nod file.
The only remaining issue is that U & V isocurves are at times flipped relative to neighbouring patch, but this only requires switching between inputs. See attached image.
Hope this helps
18 Apr 2018   [#989] In reply to [#988]
Hi James,
thanks for the new file works great and with the ability to switch Iso 'u-v' it's a bonus.
It greatly reduces the time to use Zarkow's method of smoothing transitions between
connected surfaces by Sub D.
I have already started a thread on it so will post the process using the nodeeditor
and your nod file.
Hopefully it will show advantages of using the nodeeditor.
Many thanks
Barry
19 Apr 2018   [#990]
Nice, very very nice, now I Need the Nodeeditor too. :-)
19 Apr 2018   [#991]
Where can someone find a step by step tutorial of how to use the node editor? Any link somewhere?
19 Apr 2018   [#992] In reply to [#988]
AMAZING JOB!!!!!!!
Period.
19 Apr 2018   [#993] In reply to [#988]
P.S....
James, where can I find the retopoSurfs node ?
19 Apr 2018   [#994] In reply to [#993]
Hi Marco,
Place the attached file into directory
~/Library/Application Support/Moi/nodeeditor/macros
19 Apr 2018   [#995] In reply to [#994]
Hi James.
Thanks, but...where is this folder ? "~/Library/Application Support/Moi/nodeeditor/macros"
I have a Windows machine and my folders for Node Editor are :
1) For Moi V4 : C:\Users\<user name>\AppData\Roaming\Moi\<node editor folder>
2) For Moi V3 : C:\Program Files (x86)\MoI 3.0\ui\<node editor folder>
Any help ?
19 Apr 2018   [#996] In reply to [#995]
Hi Marco,
Sorry the directory path was for a mac.
So rather it would be (for Moi V4)
C:\Users\<user name>\AppData\Roaming\Moi\nodeeditor\macros\retopoSurfs.nod
If there is not already a "macros" folder, make one.
Let me know if this doesn't work. I don't really know my way around PCs
19 Apr 2018   [#997] In reply to [#996]
Thanks a lot James!
I've tested in V4 and it works :)
Does it work also with the latest Nodeditor for MoiV3 ?
19 Apr 2018   [#998] In reply to [#996]
P.S.
I've made some experiment....what a wonderful Swiss-Army-knife for some situations where I simply want to turn a single surface to ALL QUADS!!!
Thank you very much!!!!
19 Apr 2018   [#999] In reply to [#988]
Hi James,
just tried to run nod on half sphere surface and just a tangled result.
Are there any restrictions on what surfaces the nod can be applied to.
Update once surface goes wrong all following selections go wrong as well
even those that previously worked correctly.
Barry
19 Apr 2018   [#1000] In reply to [#999]
Hi Barry
<< Are there any restrictions on what surfaces the nod can be applied to.>>
Yes, it will only work with 4 edged surface patches.
<< just tried to run nod on half sphere surface and just a tangled result.>>
This is a difficult one because you can't start with sphere solid, because it won't work with trimmed surfaces.
Attached is method for retopologizing a 3 edged hemisphere made by networked curves.
19 Apr 2018   [#1001] In reply to [#1000]
Hi James,
Ok that’s good will stipulate the 4 edge requirement in my other post.
However the concern I have is once a surface that does not meet that
requirement causes the macro to crash and the following correct
surfaces also crash.It would be good if a reset within the nod was possible.
The only way I see to reset the nod file is to close and reopen Moi ?
Anyway thanks for your help I think your macro is well worth developing.
Only wish I had the knowledge to be more help.
Barry
19 Apr 2018   [#1002] In reply to [#1001]
Hi Barry
Can you send me the .3dm file so that I may reproduce the error
and perhaps find a work around.
19 Apr 2018   [#1003] In reply to [#1002]
Hi James,
I'm using the file I posted(http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.987)
Just added a sphere and trimmed it on it's seam to make a dome surface and named it S8.
From the photo you can see the tangled result of the dome and when S7 was next applied
you can see it is also wrong.
I noticed the surfaces spike to drawing origin.
Barry
