Show messages:  1-9  …  910-929  930-949  950-969  970-989  990-1009  1010-1029  1030-1049  …  1850-1859
13 Feb 2018   [#970]
Hi Friends
an animation test of a
Mechanical Iris, entirely made in Elephant ....
I think because of the numerous Booleans made
the file is heavy, and this undoubtedly affects
on the yield of the Quartz Knot ...
in any case, for those interested
the file at this link:
http://www.mediafire.com/file/a1zwk4ha6f91dbo/Anim.Mechanical_Iris.zip
best
alberto
13 Feb 2018   [#971] In reply to [#970]
Ciao Alberto!
...ma come cacchio fai a creare certi "mostri" ?
:) :) :) scherzo...
ma...no mi funziona. Mi da in rosso i nodi "Quartz2" e "Display".
In English :
But...how do you create such "monsters" ?
:) :) :) I'm just kidding.
Anyway...it doesn't work for me. I see these nodes in red "Quartz2" and "Display".
Ciao!
P.S. I've tested with latest Moi V4
Marco (mkmd)
13 Feb 2018   [#972]
Ciao Marco
display e quartz 2 sono nodi di Ralf
Hello Marco
display end quartz 2 it Ralf's extention ,
go to this link for download
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.878
Have a nice day
alberto
13 Feb 2018   [#973] In reply to [#972]
Thanks for the link but...I really have no time to follow that discussion :)
If you can, please post the two nodes as they're form your actual config.
Thanks!
16 Feb 2018   [#974]
Hello Friends
an interesting example, I think, of creating a surface
transition between two existing ones
also quite stable ......
files at this link :
http://www.mediafire.com/file/5nznz8i85jazkm7/Between_Surf.7z
best
alberto
16 Feb 2018   [#975] In reply to [#974]
StuffitExpander on Mac says:
16 Feb 2018   [#976] In reply to [#973]
Quartz2 is inside here:
r2d3.js
16 Feb 2018   [#977] In reply to [#976]
Wanderful!
...some use case or example ?
16 Feb 2018   [#978] In reply to [#977]
I changed Karstens Quartz node to Quartz2 with the min and max as a input to sync it with the numbers of control points for my path animation Node...
pathanim.3dm
pathanim.nod
16 Feb 2018   [#979] In reply to [#978]
Ralf....I've no words!!
What a wanderful thing you did with the Node Editor!!!
I'm pretty sure that Michael never imagined that one day Moi could have been an animation software !!!
16 Feb 2018   [#980]
Very funny!
12 Mar 2018   [#981] In reply to [#242]
Now we have a free terrific solver who will avoid some headaches of the Nodes Builders fans!
http://moi3d.com/forum/index.php?webtag=MOI&msg=8858.1 :)
13 Mar 2018   [#982]
Hi Friends
I want to share this exercise
a famous mechanism .... " geneva well "
in the attached images I also show the set-up
to create the animation ...
the file is parameterized, so it is possible to modify
the number of slots in the well ...
For interested poeple the file at this link:
http://www.mediafire.com/file/hur565zl2135vsc/Mechanical_Geneva.zip
best
alberto
13 Mar 2018   [#983] In reply to [#982]
Hello Alberto!
As I've said many times here....YOU'RE A MASTER OF NODES!!!
Amazing :)
Here's a quick video : http://take.ms/bV1qz
Ciao!
13 Mar 2018   [#984]
Marco thanks for the nice words..
and for the video you made as a service to all nodeeusers ...
Thanks again
Have a nice evening
alberto
13 Mar 2018   [#985] In reply to [#984]
You're welcome Alberto!
If I may, let me give you only one little suggestion, that maybe you already know.
If you want, you could post a simple capture of Moi's screen with some, or at least, one use case of the wanderful nodes you're post here from time to time.
In this way it's easier for any user to get a quick look of what that particular node does.
And also the user is "encouraged" to download the stuff and play with it.
My two cents :)
Thanks for all your wanderful nodes!
Ciao.
12 Apr 2018   [#986]
Hi Friends
I want to share this Macro with you,certainly useful I Hope
M_Pipe
input:
-curves
-radius
- cap round =0
- cap flat = 1
If the input curves overlap the result
it is only one Brep-
file at this Link :
http://www.mediafire.com/file/wqnulsmi5hn2m3b/M_Pipe.nod
have a nice evening to all
alberto
18 Apr 2018   [#987]
Hi I need some help (as usual),
I'm using James Retop nod to generate the facets for Sub D smoothing as the Zarkow method.
I create surfaces and name them.Then using the 'get by name' selector step thro them one by one
adjusting Iso 'u-v' as required and applying the faceted results.
however sometimes the facets are connected out of order (see photo's) usually in the Iso 'u' direction.
however if I rebuild the surface (unnamed) it works correctly.
I'm using Max's latest nodeeditor and have attached Surfaces and nod files.
Barry
Retopo Surfaces.3dm
RetopoSubD.nod
Screenshot (12).png  Screenshot (13).png  Screenshot (14).png  Screenshot (15).png
18 Apr 2018   [#988] In reply to [#987]
Hi Barry,
I'm sorry about this bug in my macro. I have encountered this issue before with a similar macro: "Surface&Tile", and attempted a work around. I have pared back said macro and included it in attached .nod file.
The only remaining issue is that U & V isocurves are at times flipped relative to neighbouring patch, but this only requires switching between inputs. See attached image.
Hope this helps
18 Apr 2018   [#989] In reply to [#988]
Hi James,
thanks for the new file works great and with the ability to switch Iso 'u-v' it's a bonus.
It greatly reduces the time to use Zarkow's method of smoothing transitions between
connected surfaces by Sub D.
I have already started a thread on it so will post the process using the nodeeditor
and your nod file.
Hopefully it will show advantages of using the nodeeditor.
Many thanks
Barry
