Show messages:  1-7  …  848-867  868-887  888-907  908-927  928-947  948-967  968-987  …  1848-1859
19 Dec 2017   [#908] In reply to [#905]
Hi Barry,
You are absolute right... in the uploaded 3dm file the little MOI is double - deleting the one which is already on the path solves the problem.
Pretty sure i saved the 3dm when nodeeditor wasnt closed... thats something i have to take care of..
Thanks for finding this out!
pathanim.3dm
19 Dec 2017   [#909] In reply to [#897]
Hi Pilou, Barry found the problem - the little MOI which is on the path has to be deleted..
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.908
19 Dec 2017   [#910] In reply to [#909]
@r2d3
Excellent! Now all works like a charm!
(don't forget to edit your original post! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.878
So the French Version will be there in few minutes! Done!
Bravo!
20 Dec 2017   [#911] In reply to [#910]
Merci Pilou,
just edited the old post...
20 Dec 2017   [#912] In reply to [#911]
Funny is that you can Deform, Copy, Replace with any volumes 3 sets of "named" objects "M", "O", "I"! :)
(if you don't want have some headaches to add more 3 sets of letters! )
Idem for the path itself!
Just make all that before call the node!
20 Dec 2017   [#913] In reply to [#912]
Yes thats easy!
If you have only one object following a path - its pretty easy but if you have 3 or more objects following the same path they should have some distance - this gives some headaches..
because they have to jump to different points...and because you can change the number of points on the path with Smoothness its needs some math...
20 Dec 2017   [#914] In reply to [#913]
Users don't want use math! :)
they want just click object(s) then a path! ;)
And eventually move the sliders! :D
20 Dec 2017   [#915] In reply to [#914]
Hello Pilou,
are you talking about users or consumers;-)
20 Dec 2017   [#916] In reply to [#915]
Alas we can't be all coders even pseudo coders! ;)
Nodes are on the extrem limit of facility!
A node or assembly of nodes ready to be used is perfect for no coders!
https://www.nodebox.net not so evident! :)
20 Dec 2017   [#917] In reply to [#916]
Hello Pilou,
I try always to show how to solve a special problem, with only a few nodes, if there isn't a script available.
The nodeeditor is a programming interface by avoiding programming - for no coders.
The node editor thus authorizes non-programmers to solve their own problems.
Most of the posted stuff demonstrates only what is possible, but solves problems only for a very small group of persons, typically for the person who made it. Most of the time the nodeeditor solves the problems of a boring rainy sunday - solves problems, that we don't really have. But it's fun.
Avoiding math while using it, seems difficult for me.
But it's only my special point of view.
Have a nice day
Karsten
p.s.:Don't take everything I write so seriously;-)
20 Dec 2017   [#918] In reply to [#917]
Same for me! :)
21 Dec 2017   [#919]
Hi Friends
Some dynamic structures ........
file a this link :
http://www.mediafire.com/file/5ll93as3623zff5/Dynamic_Frames.rar
Have a nice day to all
alberto
21 Dec 2017   [#920]
Hi Santa,
I have tried to create a node that takes an input from a widget knob and and outputs until a condition is met then stops.
ie: Knob 0 to 100; if condition met at say 40 and I turn the knob further the output would remain at 40.
So HELP please I'd like idea's for Xmas.
Barry
21 Dec 2017   [#921]
Hi Barry
I am not able to create a new node, therefore, using " what
passes the Convent " I managed to do this:
http://www.mediafire.com/file/62c4anibe48kek8/Collide_Circle_Move_Versus.rar
Surely not just what you are looking for, but I hope you can
find some ideas to reach your goal
Have a nice evening
alberto
21 Dec 2017   [#922] In reply to [#920]
Ho Ho Ho Barry,
I will have a look in my bag!
A nice day to all
Karsten
limit.nod
21 Dec 2017   [#923]
Before translate nodes of extension! :)
21 Dec 2017   [#924] In reply to [#923]
Ups! Sorry for that!
p.s.: I have some more - not shared!
21 Dec 2017   [#925]
After first try! just some few are missing! :)
(only extensions Nodes! )
Array Logger are what ?
21 Dec 2017   [#926]
Thank you Santa's
now I will have something to play with on Xmas day.
Many thanks have a nice Xmas.
Barry
21 Dec 2017   [#927] In reply to [#925]
Hi Pilou!
"Array Logger" is an old node I have written many months ago.
If I remember well it takes a "PointArray" in input and writes into its UI the value of each array element.
Very useful for debugging purposes.
Marco (mkdm)
