Show messages:  1-5  …  746-765  766-785  786-805  806-825  826-845  846-865  866-885  …  1846-1859
5 Dec 2017   [#806] In reply to [#804]
Uuuuups..
same picture different file.. ;-)
animator11.nod
5 Dec 2017   [#807]
With the Animator 10 in French native
5 Dec 2017   [#808]
Animator 11 works very fine!
As you can see i must translate all! :)
Here just translated the "-Limit"!
Look "- Limite" and "+ Limit"
in fact i was too speedy I must translate in French like this "Limite -" :)
Can we have a look of the code of the macro is ?
So a very big metaphysic problem for me : must i translated all nodes or only nodes that please to me! :D
5 Dec 2017   [#809] In reply to [#805]
<<<(and i put Speed 2 : because we have only one life (not like cats who have nine! :D
var LengthOfLive=moi.GetDistance(birth,death)/speed;
if(speed<=Math.PI/2){break;}else{return;}
PS translating the nodenames makes only sense for the nodelist... if you have a LOT of nodes you have to give them relating names......
5 Dec 2017   [#810]
So the French version :)
But no exactly complete because you hid some nodes that i discovered in moving some ones !!! ;)
<< PS translating the nodenames makes only sense for the nodelist
Sure and for the Anglophobic user who has the illusion to understand a little bit of what's happening on the screen! :) :) :)
PS Thx for the Macro : indeed 2 lines can animated the world! :)
So 2 missing! (will be complete on my site! :) http://moiscript.weebly.com/elephant-systegraveme-nodal.html
5 Dec 2017   [#811]
Just a silly question! :)
Not for make it, just for info!
How do you attach something to a Macro node ?
5 Dec 2017   [#812]
Here the French last! :)
5 Dec 2017   [#813] In reply to [#811]
>> How do you attach something to a Macro node ? <<
A macro node is just an empty container until node circuitry is put inside.
To do something it needs input/s & output/s that may be connected.
Try double clicking on an existing macro to discover what is inside,
or alternatively create a new macro, double click on it, and add some node/s
include input and output from menu drop down, and then click BACK on the nav bar.
It will all become clear,
5 Dec 2017   [#814] In reply to [#813]
Aaaaaaaaaaaah damned! :)
Things hidden from the beginning world! :D
So more nodes to translate! :D
I will obtain an Universalis Encyclopedia! :)
And yes all is quasi clear now! :)
PS Can we put a macro inside a macro ?
And does exist something to alert when you create a node with a name yet existing ?
5 Dec 2017   [#815] In reply to [#814]
A macro can contain a macro.
- B
5 Dec 2017   [#816]
So Fractal world! :)
Missing a paradigm! :)
Circle is drawn inside the macro, not outside the macro!
What i missed ?
6 Dec 2017   [#817] In reply to [#816]
Hi Pilou
>> What i missed ? <<
Right Mouse Button click on "Out" in macro
select "Objects" (the default is "Numbers", no appropriate for a curve)
Also remove regular "Output" inside macro, as this will create problems.
Hope this helps
6 Dec 2017   [#818] In reply to [#817]
Bravo! Excellent!
Now the more difficult will be to not use this marvelous toy before the next year! :D
So the secret was to take "object" on the "output" in the Macro!
6 Dec 2017   [#819] In reply to [#818]
WOW!
yes, the secrets of the macros are finally discovered!
And you can save macros for reuse.
In the animator11.nod there are a couple of macros inside a macro inside a macro....
for example i made a if/else macro (f.e.: ><180) which i used for different cases...
Once you figured out a funtion -> save it as macro and reuse it for a different case...
Bon Noël <:-)
6 Dec 2017   [#820]
French Translation of the animator11.nod + Mini Manual of a Macro!
then Macro / animator11
6 Dec 2017   [#821]
Hello to all
a little exercise that starts
from a very interesting surface
the Oloid -
Some deformations , a wire that starts from
surface structure.... et voilà .....
How many interested people find the file at this link:
http://www.mediafire.com/file/qhvj5752j9y7x3f/Oloid_Bracelet.rar
have a nice evening everybody
alberto
7 Dec 2017   [#822]
Hi All,
I have had this error report when pressing run on my test collision nod.
but after I clear the error report the nod file runs ok.
Not sure if it's a bug or my nod file setup ?
The nod takes 2 objects and checks for a collision and if so moves the second object till clear.
Any thoughts ?
Barry
7 Dec 2017   [#823] In reply to [#822]
For me it looks like there is a value not set in the beginning..
Try to set defaults in the "prototype.onAdded = function()"
7 Dec 2017   [#824] In reply to [#823]
Hi Ralf,
are you referring to the Collision.js file ?
It as this at the moment Collision.prototype.onExecute = function()
Barry
7 Dec 2017   [#825] In reply to [#824]
Hi Barry,
i only have the Barry.js which still has the boolean output
Where can i fin the collision.js?
But while developing other extensions i got the same error and i was able to correct this by adding defaults in the onSdded function...
Can you post the collision.js and the nod you playing with?
