Show messages:  1-11  …  672-691  692-711  712-731  732-751  752-771  772-791  792-811  …  1852-1859
6 Nov 2017   [#732] In reply to [#731]
Wow!
Wanderful node James.
You rock!!
Ciao!
6 Nov 2017   [#733] In reply to [#731]
Looks cool James.
13 Nov 2017   [#734]
Hi friends
This is my last Macro- Rhombic Grid,
I thought of it as my utility for
the creation of the Clifford Torus-
Anyway I think it can be a tool
of wide use ...
at least I hope ,
the exercise at this link:
http://www.mediafire.com/file/0lpo8m4fxsselje/M-Rhombic_Grid.rar
Have a nice day to all
alberto
13 Nov 2017   [#735] In reply to [#734]
Nice node Alberto.
(note, getting an error with MoIV4 NEv0.97)
14 Nov 2017   [#736]
Many thanks Brian....
I have not yet tried Elephant with the New Beta V4
just released, my philosophy is to wait
Max puts his hand to new versions making
compatible
Thanks again.....
Have a nice day
alberto
14 Nov 2017   [#737] In reply to [#736]
Agreed alberto.
Tried out Motor2017 node, and CycloidGear node with V4, and they work well.
- B
17 Nov 2017   [#738]
Hi Friends
I want to share this last search
in the field of Special Surfaces, I tried to make a Variation
to Boy's Surface ...
some parts are similar to those next to (polo)
the rest I changed by doing it maybe
more feasible, I think....
file to this link:
http://www.mediafire.com/file/x13bn7kpkm11mq1/BOY_%27S_Variation.rar
Have a great weekend to all
best
alberto
19 Nov 2017   [#739]
Hi All,
Please find .nod file with spaceFrame macro.
It is a requirement for execution that extractEdges node be present.
"object2.js" to replace similar in "nodeeditor/nodes/extensions".
can be found in my earlier post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.729
Also requires most recent NE mod (Karsten's cleanup menu):
http://moi3d.com/forum/index.php?webtag=MOI&msg=8628.1
Be warned that generation time may be approx. 20 secs
20 Nov 2017   [#740]
Hi Friends
I want to share this new one
exercise of Sub Poly Triacontahedron
really interesting I think ......
file to this link:
http://www.mediafire.com/file/024zcfv5ctinjpp/New_Triacontahedron_Subd.rar
alberto
Ps- James nice result gives you exercise frame
Message 7777.741 was deleted
22 Nov 2017   [#742]
Hi Karsten,
how's everything okay?
... it's been a while since I did not live alive ..
I wanted to ask you , if it was possible to improve the tools
Fillet and Bridge ....
When you created these Extensions, if i 'm not wrong ,there were not
Extraxt and Extract Edge (James's paternity).
Now, I ask you, using the latter, you can not improve and make it
easier the procedure currently in use, which I personally believe
very laborious and unstable time ...
I wait for your new ones
Have a nice day
alberto
22 Nov 2017   [#743] In reply to [#740]
Hi Alberto,
I was inspired by your node to make simple*
nod file to create pentakis Dodecahedron
derived from solid/polyhedron.nod with Dodecahedron option.
UPDATED:
Super simple method for truncated icosahedron (well almost) included.
*It should be simpler. Hopefully we will soon have new info nodes for finding center point of a regular closed curve.
22 Nov 2017   [#744]
Hi James
I am very happy to be one of your "inspirers" Yeha ...... ,
and , even though I did not open the file, I must tell you that
PentakisPolyhedron is very usefulll for triangular tassellation
of domes or spheres-
For this purpose I send you the Truncated Icosahedron file , to get
a base for classic soccer ball construction
file to this link:
http://www.mediafire.com/file/pc5les5y6cqp4u3/CP-Truncated_Icosahedron.rar
Nb - the files are about a half ago, I think, February,
I do not know if they had been implemented by Max Polyhedron tools
in any case, in the nod. file there is all the classical construction
of the icosahedron
Have a nice day
alberto
23 Nov 2017   [#745]
Hello
For the beta V4
I have downloaded the Pentakis... familly nodes inside the last Max Smirnov
November nodeeditor.v.0.97.2017.10.05.zip + New EditorCss + Editor.js
I have "red nodes"
What is the method for make these nodes efficient ?
Does it possible ?
Or I must load a // Elephant (What is its last version ? And it's working in the beta V4)
Message 7777.746 was deleted
23 Nov 2017   [#747] In reply to [#746]
Thx
So junction between the 2 versions are not yet made!
Must have two Node editors folders specialized under the hood! :)
And that works on the Beta V4 ?
23 Nov 2017   [#748]
Hum it's not very clear to install! :) (Windows 10 OS )
Does not exist a complete folder ziped "ready to use" ?
23 Nov 2017   [#749] In reply to [#748]
@You : "...Does not exist a complete folder ziped "ready to use" ?..."
....It's the million-dollar question!!
23 Nov 2017   [#750] In reply to [#748]
Hi Pilou
Unzip attachment and replace "nodeeditor/nodes/extension" folder.
I contains "ExtractEdges" node, so you are good ti go.
<<For the beta V4>>
You will likely encounter error messages attempting to run in V4
It seems that v4 is more stringent in parsing js code.
I could not get "pentakisDodeca&TruncIcosa.nod" to execute.
23 Nov 2017   [#751] In reply to [#750]
<< Unzip attachment and replace "nodeeditor/nodes/extension" folder.
Perfect for the V3 (for me it's "extentionS" folder ! ;)
So just one folder to name/rename for use the //node editor or return to Max one!
Maybe a day i will translate all English tittles' nodes in French who are not yet made! :)
