Show messages:  1-16  …  457-476  477-496  497-516  517-536  537-556  557-576  577-596  …  1857-1859
5 Sep 2017   [#517]
Hi, guys, is there a simple way of getting the x,y,z values of the last point calculated by MathPts?
Mike.
6 Sep 2017   [#518] In reply to [#517]
Hi Mike,
>> x,y,z values of the last point calculated by MathPts <<
MathPts "f(uv)"input into "InPts" ArrayExt/idxSelect node
Multiply Unum X Vnum minus 1 for input into "idx" on ArrayExt/idxSelect node
then "Out" input into Points2/splitPt to get x,y,z values.
An alternative is to use ArrayExt/ArrayFlipper to idSelect with index of 0
If this does not make sense, upload your file & I modify it
6 Sep 2017   [#519] In reply to [#518]
Thanks, James. That's certainly a more elegant method than the work around I was using.
However... right now it's not giving quite the same result. I'll try and figure out where I've gone wrong tomorrow.
Mike.
6 Sep 2017   [#520] In reply to [#519]
Hi Mike,
I have attached nod file showing both methods.
Red & Blue sphere are used as placeholders to
demonstrate location set by xyz of arrays last point.
basic/length node as used for point numbering above
could be used instead of math node multiplying U & V values.
6 Sep 2017   [#521] In reply to [#520]
Thanks, again.
Well, I don't know what I was doing wrong, but in the cold light of day both the array techniques you suggested now seem to work just fine.
Onwards and upwards.
Mike.
7 Sep 2017   [#522] In reply to [#521]
Hello Mike,
please check also the RMB on the idxSelect node - you can also Switch it to the selection of values in numarrays or geometry of objectlists.
Have a nice day
Karsten
7 Sep 2017   [#523]
Hi all,
Loosely based on "Recreating Jean Nouvel's Louvre Abu Dhabi with Parametric Modeling"
https://www.youtube.com/watch?v=iRVMx4WzFus
see nod file attached
7 Sep 2017   [#524] In reply to [#523]
Wow!
It's a pleasure to see the decryption of the geometry.
Thank's for sharing!
Karsten
Message 7777.525 was deleted
7 Sep 2017   [#526] In reply to [#525]
Nice interlacing!
8 Sep 2017   [#527] In reply to [#522]
Re: please check also the RMB on the idxSelect node - you can also Switch it to the selection of values in numarrays or geometry of objectlists.
Thanks, Karsten, for pointing that out.
Mike.
8 Sep 2017   [#528] In reply to [#523]
Amazing.
I won't be tackling anything like that for a very long time.
Mike.
13 Sep 2017   [#529]
Hi All,
UPDATED: nod file attached
This is still a work in progress,
but as a teaser I have attached screen grab
of a parametric brick wall.
I'll get back to it on the weekend.
Message 7777.530 was deleted
15 Sep 2017   [#531]
Hello All
I continue exploring the Super Forms,
after Superellipse ,
now, it's the turn of SuperToroid-
By varying some parameters we get many different
Forms, really interesting, based on possible adaptations
of the Ring or Path ,and the Circle or Profile -
How many interested people find the file:https:
//www.mediafire.com/file/8saajmc34cx0ku6/Super%20Toroid.rar
Have a nice week and to all
al
15 Sep 2017   [#532] In reply to [#531]
The node is very cool, AL2000!
I've recently encountered papers on super cyclides.
15 Sep 2017   [#533] In reply to [#524]
Hi Karsten,
I am trying to take an array of values (curve length in my particular case)
and arrange them in order ascending &/or descending. In this way,
first and last values can be idxSelect to give range domain (num0,numN)
Can this be done with "logic/compare" node or is there need for a “sort” node?
(i understand that javascript sort() method specifically manipulates strings ,
but can be made to sort numerical values in conjunction with compare function)
Also I have be watching online grasshopper tutorials in an effort to vary spacing of points on a curve dependant degree of curvature.
Anyway I came across the “Remap” node in grasshopper, that will reassign a num
array to range between inputted domain. I remembered that you had contributed "infos/reMap" node (2 as it turns out). Unless I am mistaken they replicate the function of Max’s Basic/Interp node. If you were so inclined, I think there would be value in rewriting your node to emulate the function of grasshopper’s namesake.
This is not so much a request, more a suggestion of something that you may like to do so that your old nodes are not ignored like redheaded step-children.
Have a great weekend
15 Sep 2017   [#534]
Please put some images result of all these news nodes! :)
Message 7777.535 was deleted
Message 7777.536 was deleted
